Fuel cut question...
Old Apr 29, 2004 | 12:12 PM
DA-MAX's Avatar
Default Fuel cut question...
this might be in general on all cars, but in particular on Hondas, when you hit fuel cut does the ECU interrupt/cut out the fuel injector signal coming from each injector power wire from the ECU or does it just interrupt/cut the main fuel relay signal(rather than each injector signal)? sorry if its not clear. I'm kinda curious though
Old Apr 29, 2004 | 12:45 PM
Chiovnidca's Avatar
Default Re: Fuel cut question... (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">this might be in general on all cars, but in particular on Hondas, when you hit fuel cut does the ECU interrupt/cut out the fuel injector signal coming from each injector power wire from the ECU or does it just interrupt/cut the main fuel relay signal(rather than each injector signal)? sorry if its not clear. I'm kinda curious though </TD></TR></TABLE>
The ECU stops supplying ground to the injectors. Doesn't affect the main relay at all.
Vtec04
Sep 28, 2017 05:05 PM
BseriesEKhatch
Feb 28, 2014 05:11 PM
98vtec
Mar 18, 2008 07:36 PM
boosted_LS
Jul 6, 2005 09:01 PM
LODOSS
Dec 20, 2003 10:37 PM
