technical question
Old Dec 19, 2003 | 06:39 PM
LODOSS's Avatar
Default technical question
I was wondering if anyone can answer this for me.
Does the Main Fuel Relay power the ECU?? so .. say if there is no fuel and the main fuel relay detects it.. it won't power the ECU . correct? which means that if there is no fuel in the car SAFC/VAFC or whatever connected to the IG wire to the ECU won't power up ?
Old Dec 19, 2003 | 08:10 PM
LODOSS's Avatar
Default Re: technical question (LODOSS)
up for the pros
Old Dec 20, 2003 | 09:16 AM
LODOSS's Avatar
no one knows?
Old Dec 20, 2003 | 10:01 AM
4crx4me's Avatar
Im not positive on this but reasonably sure that the main relay and the ECU are ALWAYS hot.
The main relay simply sends it's power to the fuel pump to pressuize the system, and the PGM- FI circuts to fire the injectors at the proper time.
HTH
Old Dec 20, 2003 | 10:33 PM
2G0S0R1's Avatar
New User
Default Re: technical question (4crx4me)
my 01 gsr ecu has a separate IGN power that is hot, with or without the fuel relay.
Old Dec 20, 2003 | 10:37 PM
4crx4me's Avatar
Default Re: technical question (2G0S0R1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 &raquo;</TD></TR><TR><TD CLASS="quote">my 01 gsr ecu has a separate IGN power that is hot, with or without the fuel relay.</TD></TR></TABLE>
I think you might be right. And I was wrong.
Check a helms for confirmation
Calundeen
May 20, 2019 08:02 AM
K20AllMotorEF8
Mar 1, 2012 04:04 PM
fusion645
Audio / Security / Video
May 13, 2010 09:10 AM
red_honda_racer
Nov 22, 2007 12:33 PM
95turboeg
Jul 7, 2006 11:38 AM
