front susp. problem(something is not right)
Old Aug 16, 2002 | 08:15 AM
sleeperaccordv6's Avatar
From: west Ft.Worth, Texas, the big one in the center
Default front susp. problem(something is not right)
A while back while going down some back roads, kindof runnin hard following my my friend in his 1500. He barley missed it and I slammed into a hole/pothole w/ my front right wheel. I mean I smacked it hard( thought I had blown my tire) and now it tends to wander a little at highy. speeds.while braking if I have the wheel turned slightly it tries to pull that way, it's easly corrected tho. just wandering what I myight have bent,loosend or broke?
Old Aug 16, 2002 | 08:43 AM
FUP23's Avatar
New User
Default Re: front susp. problem(something is not right) (sleeperaccordv6)
Just get an alignment man ...Just knocked the **** out of your alignment ..
Old Aug 16, 2002 | 08:49 AM
Default Re: front susp. problem(something is not right) (Devin17)
to me but what do allignments usualy run?
Old Aug 16, 2002 | 09:38 AM
Katman's Avatar
around $40-80 bucks, depending on where you go. Just call around to local alignment shops. Check out some tire places, some of them usually provide alignment services or PepBoys even.
Old Aug 16, 2002 | 10:40 AM
Default Re: front susp. problem(something is not right) (Katman)
thanks...to all.
Old Aug 16, 2002 | 10:44 AM
93CivicSI's Avatar
could have damaged your tie rrod end on that side - jack up the car on the side that you hit and see if there is any play in your steering.
Old Aug 16, 2002 | 12:07 PM
Default Re: front susp. problem(something is not right) (93CivicSI)
do any of y'all have a diagram of the susp. for my car?(see sig)
Johnny Gdq
Honda CR-V & Element
Feb 28, 2019 07:30 AM
Johnny Gdq
Sep 4, 2018 12:31 AM
shotgun2224
Aug 18, 2007 10:03 PM
silver ej
Jun 29, 2005 01:30 PM
solo-x
Nov 21, 2002 09:26 AM
