front hood doesn't close
Old Sep 1, 2011 | 08:16 AM
creation25's Avatar
Default front hood doesn't close
don't know where this should go. so if it's not in the correct thread pls move it somewhere else. my front hood doesn't seem to fully close. there are side molding underneath the hood all around the corner and i suspect that is the problem. can somebody confirm this problem? should i remove the side molding?
Old Sep 1, 2011 | 08:22 AM
grumblemarc's Avatar
The Grumpiest
Default Re: front hood doesn't close
The hood won't close since when? What car are we even talking about? Please try not to be so vague.
Old Sep 1, 2011 | 09:30 AM
creation25's Avatar
sorry, i thought it would be common sense. it's an 92 civic hatch. i bought it that way 1 month ago. the front hood doesn't close fully, i'd say about an 1 1/2 -2 inch off. there is a side molding that is attached underneath the hood. i wonder if that may be causing the hood not to fully close. will try to take it off and see.
Old Sep 1, 2011 | 10:02 AM
The Grumpiest
Side molding? Having a hard time picturing what it is you're talking about. 2"? That seems to be a bit drastic an estimate. Did you check the latching mechanism? You've been driving this in this condition? I hope not.
Old Sep 1, 2011 | 12:45 PM
Ci-v-iC's Avatar
It's probably not side molding you're talking about; there is a piece of rubber trim along the front lip of the hood and no, it is not your problem.
Civics had a TSB for a front latch. Basically, if I remember correctly, you have to take 4 bolts out of the latch mechanism to take it completely out. Before you do it, mark the exact position of the latch mounting.
Clean the latch by giving it an overnight soak in gas, then grease it, check for smooth operation and remount it. Good luck.
H22palms
Jul 9, 2013 02:03 PM
///Nick
Jan 12, 2011 01:21 PM
burnt_clutch
Jan 24, 2007 07:14 PM
jdmjeff
Jan 19, 2005 04:09 PM
enthusiast128
Jan 27, 2002 08:47 AM
