front crank seal HELP
Old Jun 26, 2007 | 09:37 AM
DIY16KID's Avatar
Default front crank seal HELP
ive done went threw 7 an everyone of'm leaked hard. the last one worked for about a week. is there anything yall ever done to fix it other than replacen the crank?
Old Jun 26, 2007 | 04:32 PM
DIY16KID's Avatar
Default Re: front crank seal HELP (DIY16KID)
bump, damn aint none of yall ever had this problam?
Old Jun 26, 2007 | 05:27 PM
hatchling37's Avatar
Go rent a seal driver, be patient, and do it right the 8th time
Old Jun 26, 2007 | 06:07 PM
DIY16KID's Avatar
Default Re: front crank seal HELP (hatchling37)
i did it right not with a seal driver, the cranks got a nick in it an i wasnt gonna put another one in untill i knew there wasnt noone thats ran into it an figured out what you could do about it. it worked good leavin it out a little bit but when i was tunin last night it started leakin again. if it jus spun im silicone it in an see how it works. sound like a good idea?
Old Jun 26, 2007 | 07:48 PM
dtapia's Avatar
you can use emeroy cloth to get the bur out if it is small . how bad is the nick?
Old Jun 26, 2007 | 10:43 PM
DecentCivicZ6's Avatar
B A N N E D
dang, doesnt sound to good...cranks arent that expensive tho...not an OEM used.
Old Jun 26, 2007 | 11:31 PM
DIY16KID's Avatar
Default Re: (DecentCivicZ6)
yea i heard about that cloth, how much? the nicks bad but not to bad, i was gona say expletive it an tke it out an go ahead an throw the d17crank an some d16a1 pistons but i needa fix it quick, i aint gotta ride to work.
Old Jun 27, 2007 | 06:04 AM
B A N N E D
say what d17 crank in a D16? friends got an extra crank if ya need one out of his shitty d17 vtec that exploded after 30k miles.
Old Jun 27, 2007 | 11:27 AM
DIY16KID's Avatar
how much you think he wants for it? yea i MIGHT go ls rods in it, i gotta figure out what kinda rods ima use an see if i gotta take it to the machine shop or not.
Old Jun 27, 2007 | 09:44 PM
TooManyTickets's Avatar
Default Re: (DIY16KID)
u dont need a new crank.. but if it has a nick in it, it needs to be polished up. take it to a machine shop and see if they can do it for a few $$
Old Jun 28, 2007 | 09:40 AM
DIY16KID's Avatar
Default Re: (TooManyTickets)
if ima take the motor right back out ima go ahead an use a different crank anyways. its bad enough to be replaced but ima tryin figure somethin out for it.
Old Jun 28, 2007 | 10:09 AM
Bakeoff's Avatar
You use thw worst grammar of anyone I've ever seen on the internet. I had to reread your first post three times to understand it.
Because of that, I can't bring myself to help you.
Old Jun 28, 2007 | 06:17 PM
DIY16KID's Avatar
Default Re: (Bakeoff)
i aint get on here to hear **** about i cant talk over a computer.
i tore everything down today an turns out the crank seal wasnt leakin anymore, its the cam seal. thats 2 front seals that done started leakin.
yall think i needa tear it down an have everything balanced?
Old Jun 28, 2007 | 06:55 PM
i dont think anything being out of balance would cause leaking... sounds to me like some seals have just gone bad and need replacing
Old Jun 28, 2007 | 07:24 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
just replace the leaky seals.
Old Jun 28, 2007 | 07:43 PM
DIY16KID's Avatar
Default Re: (full Circling)
thats the point, i aint the type that juss buys a motor an throws it in. i checked everything an put all new gaskets in it. the cam an crank front seals are brand new, i went threw a couple crank seals before i had to rig it an now it the front cam seal. idk what the hells goin on with it
Teamdiesel
Nov 19, 2012 03:37 PM
EGcivic_95
Jan 7, 2012 11:11 PM
sdr KEL
Apr 26, 2009 08:53 AM
88crxdxfastwhip
Aug 31, 2005 11:24 AM
kingteghelm
May 2, 2005 11:49 AM
