Front brakes
Old Oct 10, 2007 | 04:46 PM
huge230's Avatar
Default Front brakes
I have searched and want to try and get an answer straight. If Im starting with DC front spindles can I just bolt on
17CL15VN calipers (97-99 RL, ITR calipers, maybe others)
23T brackets
and re drilled prelude rotors?
Is it as simple as that?
Old Oct 11, 2007 | 07:34 PM
roastbeefrichie's Avatar
Default Re: Front brakes (huge230)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">I have searched and want to try and get an answer straight. If Im starting with DC front spindles can I just bolt on
23T brackets
Is it as simple as that?</TD></TR></TABLE>
if you have a 94-00 integra front knuckles, the integra type-r caliper (stamped 17cl15vn) can be found in junkyards (from itr, accord, prelude, older legend, vigor, cl, rl, tl, cr-v, etc) are NOT a direct bolt-on due to the offset of the rotor. if you were to try to bolt it on directly, the rotor would hit the inside of the caliper bracket, and the wheel would not spin. you will need to seperate the bracket (stamped 23T or 25T) from the 17cl15vn caliper. the brackets will need to sent to the machine shop & milled 2-3mm (or 1/8"). the +97 prelude 11" rotors must be re-drilled to 4X100. with the milled 23T brackets, this will work for the itr 17cl15vn...and the legend gs 2-pot or nsx calipers as well
https://honda-tech.com/zerothread?id=734560
pm BrakeExpert, he machines 23T brackets, re-drills rotors & specializes in oem honda brake upgrades
Modified by roastbeefrichie at 11:50 PM 10/11/2007
Old Oct 11, 2007 | 08:50 PM
doood's Avatar
been there done that
Default Re: Front brakes (roastbeefrichie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by roastbeefrichie at 11:50 PM 10/11/2007</TD></TR></TABLE>
you could do this method or use a 2mm spacer behind the rotor
Old Oct 11, 2007 | 09:16 PM
Default Re: Front brakes (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
you could do this method or use a 2mm spacer behind the rotor</TD></TR></TABLE>
Old Oct 12, 2007 | 12:30 PM
huge230's Avatar
thanks great link, just what i was looking for
Old Oct 12, 2007 | 07:49 PM
gunnerman
Suspension & Brakes
Feb 6, 2011 08:58 PM
jfoster
Suspension & Brakes
Mar 29, 2009 07:58 PM
Understeer
May 1, 2006 07:20 PM
sockvtec
Oct 8, 2005 12:59 PM
Petah
Aug 14, 2002 09:00 AM
