Fresh air vent stuck open
Old Jul 31, 2009 | 04:14 PM
category5 SI's Avatar
Default Fresh air vent stuck open
I have a 99 civic si and when I hit the recirculation button, the vent for outside air does'nt close, it's stuck open.I checked all fuses and everything else on climate control works, the button is even lit up.I can smell other cars exhaust threw my vent it sucks. Is there anyway to manually close it?
Old Aug 6, 2009 | 12:41 PM
Default Re: Fresh air vent stuck open
I've checked everything, I don't get why it won't close.
Old Aug 6, 2009 | 06:21 PM
fcm's Avatar
fcm
Old Fart
Recirculation control motor either unplugged or N/G.
Access motor, make sure black/yellow lead has power, [ign. switch on/engine running] check for ground on green/red, [from recirc switch] and/or green/white, [fresh air switch].
This^^^ assumes wire colors are the same for 96-98 civics and 99 Civics.
The only manual way to do it, [motor N/G] would be to remove motor, open case, manually turn motor to recirc, reinstall motor to hold recirculation door closed.
Better yet, replace the motor. 94
Old Aug 6, 2009 | 08:22 PM
Thanks, I'll have to check the motor tomorrow.
Old Aug 29, 2009 | 03:59 PM
Where is recirculation control motor located?
pityocamptes
Aug 9, 2014 09:03 PM
Krivsky
Aug 8, 2013 04:17 AM
s13hero
Acura TL, RL & ZDX
Aug 13, 2011 03:03 PM
Dbach
Nov 12, 2008 12:01 PM
daidilus
Dec 10, 2004 04:16 PM
