Forged pistons or rods??
hello, i am currenty spraying a 50 shot on my d16 SOHC motor. I am planning on moving up to a 75 shot,but i want to make my motor a little stronger first. I don't have a lot to spend so would i benifit more from forged pistons or forged rods? if i get the forged pistons, i have heard LS rods can be modified to work in a d series motor. and also some better rod bolts.
dont do 1 without the other
if you are going to take the time bo tear down your engine the minimal cost to replace the other one is well worth it.
well i have a scratch in my cylinder wall so i have to tear apart my motor anyway, i noticed this while changing a head gasket. by the way i changed my headgasket in 35 minutes, thats my personal best.
well what is your budget first? that will determine where the money should be spent. lets say you have $1600.00 that will get you the forged pistons and a full fresh rebuild on the block. and another $350 or so more should get you rods as well. just some numbers to give you an idea.
kpjo4
Mar 11, 2010 07:56 PM
Jeanious
Dec 4, 2007 12:41 PM
JunIntegra
Mar 19, 2004 04:18 PM
