flywheel ring gear
Old Nov 15, 2005 | 09:17 PM
zman's Avatar
Default flywheel ring gear
The ring gear on my flywheel is messed up. Sometime when i start the car it just makes a funny noise and doesn't start, the starters not spinning the flywheel because the ring gear is messed up. We changed the flywheel and the problem is gone.
Now my question is can i get a new flywheel ring gear for the flywheel. Its a lightened flywheel and i want to be able to use it again. Where would i get this flywheel ring gear? Approximate price?
Old Nov 16, 2005 | 04:37 AM
NJIN BUILDR's Avatar
Default Re: flywheel ring gear (zman)
Honda doesn't sell replacement ring gears for their stock flywheels.If its an aftermarket flywheel with a separate ring gear you should be able to get one.Give the manufacturer a call and they can tell you the price.
Glenn
mlh996
Dec 24, 2017 11:22 AM
thewrai6th
Transmission & Drivetrain
Nov 3, 2009 06:09 PM
thewrai6th
Nov 2, 2009 08:44 PM
Manguish
May 6, 2003 07:07 AM
