Flywheel question
Old Jan 5, 2007 | 05:31 PM
LDS's Avatar
LDS
Default Flywheel question
Can you install a flywheelwith no air tools and if so whats the best way? I have the transmission removed and clutch off but the bolts are really on there.
Old Jan 5, 2007 | 07:36 PM
LDS's Avatar
LDS
I have the impact screwdriver from when I did the brakes on my wifes type-r. I would have never thought that would work. Ok so tomorrow I will try this. I will update tomorrow.
Old Jan 5, 2007 | 09:36 PM
white90crxhf's Avatar
you can use part of the left side transmission mount and stick a bolt into the engine block, and use one of the bolts for the pressure plate and it will keep the crank from spinning... i'll take a picture when i install my next transmission if it doesnt make sense.
Old Jan 6, 2007 | 06:02 AM
LDS's Avatar
LDS
Sweet awsome pics. I cant wait to go over there this morning to give it a shot! By the way My impact screwdrvier is the one with the built in hex. oh well i find something to work . thanks for the help.
Old Jan 6, 2007 | 12:10 PM
VRD^don's Avatar
Default Re: (LDS)
no...impact screw driver wont get it out...just have someon on the other end of the motor...have them use a 19mm on the crank to stop it from spinning and u can loosen those flywheel bolts..
Old Jan 6, 2007 | 10:33 PM
LDS's Avatar
LDS
My friend ended up being able to bring his air tools and compreesor over so I used them. Everything worked out great.
The car is back up and running and now revs faster plus chirps third. All in all im pretty happy.
Thanks to everyone who helped with advice.
Old Jan 7, 2007 | 06:41 AM
F20Cteg's Avatar
Default Re: (LDS)
Enzo, nice, but too much work and doesn't work with all flywheels.
I use a wrench and put the box end on the 17mm and the open end against a pressure plate bolt. Works perfect.
soodominican
May 9, 2009 01:39 PM
freshly boosted DOHC ZC
Jun 10, 2007 05:51 PM
navin
Apr 4, 2002 06:46 PM
FUP23
Feb 17, 2002 03:33 PM
