flywheel??!!
Old Jul 8, 2003 | 07:51 AM
gezer's Avatar
Default flywheel??!!
hey i was gonna take out my flywheel to get it resurfaced cause its making all kinds of noise, but iam hesitating because i heard it has to be torqued down?? is that true, cause i dont have a torque wrench or anything. So em i just screwed or is there away around this??
Old Jul 8, 2003 | 09:12 AM
RCautoworks's Avatar
Default Re: flywheel??!! (gezer)
Well they need to be torqued to 85, and I know some craftsmen torque wrenches stop at 75. So just tighten them really tight, I mean really tight, and use some thread locker and you will be fine. While you have it out, change the bearing inside the flywheel to.
Old Jul 8, 2003 | 09:15 AM
Kataku2K3's Avatar
I would recommend buying a torque wrench, even a cheap one will do for a flywheel... 76ft/lbs. is all it takes for a B series motor and 87ft/lbs. in the SOHC world... I'm sure you could get away without torquing it but I would NOT recommend that at all... Get a torque, resurface the flywheel, pop everything back on, and you'll be set... Good Luck
EDIT: NOT ALL CRAFTSMAN TORQUE WRENCHES STOP AT 75ft/lbs., maybe the 3/8" drive but the 1/2" goes to 150... If you wanna spend some money invest in a Snap On, that's what we use at the shop... We only use them on motor stuff tho, the Craftmans and stuff are for torquing wheels, etc...
Old Jul 8, 2003 | 09:19 AM
Vinceg99's Avatar
Default Re: flywheel??!! (Kataku2K3)
I agree buy even a cheap one (which is still accurate) I bought one for like $30 bucks or so from Autzone and it goes from like 15-90 ft.lbs or something like that. I must say that it seems to be right on as well. They all have to be within some kind of specs so even a cheaper one would be fine. Also the one I bought has a lifetime warranty so well if i feel its off I will just get a new one.
Old Jul 8, 2003 | 09:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: NOT ALL CRAFTSMAN TORQUE WRENCHES STOP AT 75ft/lbs., maybe the 3/8" drive but the 1/2" goes to 150... If you wanna spend some money invest in a Snap On, that's what we use at the shop... We only use them on motor stuff tho, the Craftmans and stuff are for torquing wheels, etc... </TD></TR></TABLE>
Yep, thats why I never said all.
Old Jul 8, 2003 | 09:36 AM
Kataku2K3's Avatar
Default Re: flywheel??!! (90blackcrx)
My bad, I didn't even see the "some"... It's all good tho, I think he gets the point... Peace
Jk_DC2
Feb 17, 2009 10:40 AM
lastturn
Jul 15, 2005 05:15 PM
madswapper
May 1, 2005 05:01 PM
AllMoToRB18c
Jun 29, 2003 11:24 PM
