Flooring it, but not going fast???
Old Jul 7, 2003 | 08:08 PM
VtecDA9's Avatar
Default Flooring it, but not going fast???
The car seems like it's not getting all it's power somehow.... It revs up, vtec hits, but it's not as fast as it used to be.... 1600 on the new motor... no smoke, engine runs fine in the low end, but when I smash on it, something doesn't feel right... I still get that egg smell, blown cat orclutch?
Old Jul 7, 2003 | 08:32 PM
97hb's Avatar
Default Re: Flooring it, but not going fast??? (VtecDA9)
Could be your clutch.
Old Jul 7, 2003 | 09:36 PM
VtecDA9's Avatar
Hmmm, Would it probably be just the disc or the pressure plate...? How could I tell if the pressure plate is going bad? The clutch has less then 15,000 miles on it... ACT HDPP and 6 puck.....
Old Jul 7, 2003 | 09:46 PM
MikeSarr_GSR's Avatar
it could be anything... how long you been driving your new motor
WOT VTEC? since what milage...
Old Jul 7, 2003 | 11:17 PM
gumbybum's Avatar
try to tighten your throttle cable, i had this problem and i tightened that bad boy and it pulls sooo much harder. i hope that this helps dood
Old Jul 7, 2003 | 11:42 PM
xteg95's Avatar
Default Re: Flooring it, but not going fast??? (gumbybum)
when you floor it does it fell like its just revving...cause if it does thats usually your clutch clipping. if not its something w/the motor.
Old Jul 8, 2003 | 12:54 AM
Vinceg99's Avatar
Default Re: Flooring it, but not going fast??? (xteg01)
How old is your exhaust? Could be a partially clogged cat as well.
Old Jul 8, 2003 | 07:42 AM
VtecDA9's Avatar
Yeah, I'm going to adjust my clutch cable, but I am not sure how far to tighten it... As far as the cat, it's a new carsound cat with 1600 miles on it. So does that mean the clutch is wearing, or the cable just needs adjsutment?
Old Jul 8, 2003 | 11:51 AM
preluder's Avatar
I think your clutch is worn from too much revving or racing too hard. Mine had the same problem be prepared to have it changed soon
Old Jul 8, 2003 | 06:48 PM
VtecDA9's Avatar
Default Re: Flooring it, but not going fast??? (preluder)
So would it be the disc that needs replacing or the pressure plate? The ACT HDPP is less than 2 years old and doesn't have that many miles on them... I know the 6 puck is prolly worn from all that feathering in traffic... You think i'd be cool just getting replacing the disc to a full faced?
Old Jul 8, 2003 | 09:20 PM
Mohudsolo's Avatar
If the revs pick up but the car does not accelerate, then the clutch is slipping. If the motor revs slowly, it's plugged up. Check timing, make sure the intake is not restricted, pull the exhaust off the converter and look it over. If you can get away with making some noise, disconnect the head pipe from the converter and try a short drive. Make sure there is no damage to the rest of the exhaust. No dents in the pipe or damage to the muffler. I've seen loose baffles block the exhaust.
The not power, revs sluggish sounds like a clogged exhaust. I've seen converters melt and break apart and really clog the flow off. It's only a few bolts under the car to check. I would really start there. You'll have to disconnect that to get the trans off to change the clutch if it's not the problem anyway. New parts do not equal can't be the problem. New parts can be bad too.
Gary Albano
Apr 8, 2013 02:56 PM
xTimmyx
Dec 10, 2011 05:57 AM
alexsracing
Feb 14, 2005 04:41 PM
bloodyknuckles
Jun 4, 2004 07:26 PM
