Fine tuning a 2000 Civic Si
Old Dec 11, 2002 | 06:37 PM
Kicklow's Avatar
Default Fine tuning a 2000 Civic Si
I currently have a 2000 Civic Si and I am not the most knowledgable person when it comes to all of the fine tuning of the engine. I currently have an HKS Hyper Cat-back exhaust, AEM Cold Air Intake, B&M Fuel Pressure Regulator, Skunk2 Cam Gears will be here in about a week, along with a Skunk2 Short Shifter. I have the timing advanced just slightly and the fuel pressure is currently at 38 at idle. what or some small things that I could do to try to maximize the power for what I currently have done? With the cam gears, what would the best setting be while everything else is stock? I appreciate all the help. Thanx - Justin
are there any other mods that would help out with the set up that i have so far that are relatively inexpensive?>
[Modified by Kicklow, 12:09 AM 12/12/2002]
Old Dec 11, 2002 | 06:42 PM
piscorpio's Avatar
Default Re: Fine tuning a 2000 Civic Si (Kicklow)
dyno time!
Old Dec 11, 2002 | 06:50 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (piscorpio)
you wouldnt happen to know of any place around the NY state area that does dyno testing do you?> i sure dont
Old Dec 11, 2002 | 07:06 PM
piscorpio's Avatar
Nope, sorry. Maybe some one local can help...bump for you.
Old Dec 11, 2002 | 08:51 PM
3rdGteg's Avatar
are there any other mods that would help out with the set up that i have so far that are relatively inexpensive?>[Modified by Kicklow, 12:09 AM 12/12/2002]
I'd get a pair of more aggresive camshafts.
Old Dec 11, 2002 | 09:15 PM
stupidfast's Avatar
Default Re: Fine tuning a 2000 Civic Si (3rdGteg)
Bump fuel pressure to 46 psi with the hose disconnected. Put an itr intake cam in it and it will run alot better with some tuning..
Old Dec 15, 2002 | 06:07 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (stupidfast)
do performance plugs and wires make a significant difference?> how does the addition of a 4-2-1 ceramic DC header sound?> those were prolly going to be the next additon.
Old Dec 15, 2002 | 06:27 PM
swrdply400mrelay's Avatar
Plugs and wires don't do much. A header would be good, and so would a skunk2 intake manifold.
Old Dec 15, 2002 | 06:38 PM
GZERO's Avatar
Default Re: Fine tuning a 2000 Civic Si (swrdply400mrelay)
a vafc can help squeeze a lil hp, but don't get your hopes up
Old Dec 15, 2002 | 06:55 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Fine tuning a 2000 Civic Si (GZERO)
cam gears are barely worth anything without new cams.
Old Dec 16, 2002 | 12:42 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (dLo GSR)
im looking into the skunk2 intake manifold along with the skunk2 stage 1 cams....just have to find the funds for them first. does anyone know where the closest place would be to get my car dyno tested? im in albany, NY thanx
Old Dec 16, 2002 | 12:56 PM
TheHater
Guest
Posts: n/a
Type r intake manifold, type r cams, type r inner valve springs and you will be able to safely rev higher.
Old Dec 16, 2002 | 01:08 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (BOOSTINSI)
how do those compare price-wise to the skunk2 products, and wherewho would you recommend getting them from?
Old Dec 16, 2002 | 05:13 PM
ITR cams
Old Dec 16, 2002 | 05:26 PM
Desslok's Avatar
Bump up the fuel pressure as stated above. Cam gears- try intake advanced 2 degrees, exhaust retarded 1 degree. That should give you some gain until you can get it to a dyno tuner.
Old Dec 16, 2002 | 07:15 PM
slvrcivic97's Avatar
Default Re: Fine tuning a 2000 Civic Si (sp)
youv'e probably heard of this site and not to take people away from honda-tech, but try www.clubsi.com and go to their tips and tricks and performance forums.
Old Dec 17, 2002 | 12:05 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (slvrcivic97)
I have the FPR installed and i am trying to hook up the A/F ratio guage.....i need to hook one of the guage wires into the O2 sensor...there are four wires in my O2 sensor...would anyone happen to know which wire i need to connect to? if i can remember correclty there were 2 black, 1 white, and 1 green....i may be wrong on the colors.....i do know that 2 were the same color and the other 2 were different.
Old Dec 18, 2002 | 11:35 AM
texasSI's Avatar
I Fraud My Insurance Company
its the white one, hook it up near the computer though. much easier
Old Dec 21, 2002 | 02:21 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (texasSI)
Just wanted to say thanx to everyone that helped. and just so everyone knows...if you have any ideas or advice my ears are open!!! thanx again, justin
Old Dec 22, 2002 | 02:45 PM
upstatecrx's Avatar
CTR intake cam , more lift than ITR , ITR exhaust cam, intake manifold only helps really with head work and cams, but it won't hurt. and get a header. the skunk 2 stage 1 cams have very similar specs to the type R cams.also new inner valve springs. and don't get a VTEC controller unless you know what you are doing otherwise you car will just run worse. run stock plugs. if you want wires get some NGKs . they run around $50.
[Modified by upstatecrx, 6:47 PM 12/22/2002]
Old Dec 22, 2002 | 05:37 PM
Kicklow's Avatar
Default Re: Fine tuning a 2000 Civic Si (upstatecrx)
where would i be able to get some literature or know-how on what to do with the VTEC controller? Why would you run stock plugs over after-market?
Old Dec 22, 2002 | 07:59 PM
stupidfast's Avatar
Just so you know skunk cams are not similar to R cams. They are alot more aggressive..good for 10 plus whp over R cams.
Old Dec 22, 2002 | 08:33 PM
qcoffey's Avatar
I agree. After I did my bolt on mods last year(Greddy Header & Evo Exhaust, AEM CAI etc.) I put my car on the Dyno at the Carlisle, PA show. They did some quick tuning in between my 2nd and 3rd runs. I gained 12 hp in the 5000rpm to 7000rpm range. The power also started coming on at about 4700rpm instead of about 5200rpm. The Apex-i VAFC is a good tuning unit for not a lot of money.
siisgood00
May 9, 2007 04:28 PM
siisgood00
14
Feb 27, 2007 03:42 PM
Im-Gay
Aug 22, 2004 04:31 PM
EkHatch1
Jul 27, 2004 04:35 PM
Taylor19si
Mar 2, 2004 05:23 PM
