fidanza friction disk replaceability and lifespan
Old Apr 23, 2007 | 08:11 PM
sil's Avatar
sil
Default fidanza friction disk replaceability and lifespan
What's the lifespan of the fidanza friction disk? a while back I installed the Al flywheel with an exedy stage 1 clutch and it feels like the clutch will need to be replaced soon, starting to get some serious chatter and engagement inconsistencies, similar to when my OEM clutch started to wear out.. haven't heard of many people actually replacing the friction disk, but should I be looking to replace it if I wanted to keep the flywheel (ie. is it similar to brake rotors where if using new pads you'd need to resurface rotors?) I'd probably be going back to an OEM clutch.. this is on an 99 Si(R) B16a2
Thanks!
Old Apr 24, 2007 | 03:34 PM
Lubo_25's Avatar
Default Re: fidanza friction disk replaceability and lifespan (sil)
everything can be summed up in how you drive...they can either last 8 yrs or what not or 8 days...
Old Apr 24, 2007 | 03:36 PM
sil's Avatar
sil
Default Re: fidanza friction disk replaceability and lifespan (Lubo_25)
right, I agree.. mine was mostly highway driving, and no drag style launches.. my question was if it is necessary to change if similar to how one should resurface a rotor when changing out pads
Old Apr 24, 2007 | 03:43 PM
FarinaMotorsports's Avatar
You can just have it resurfaced. You don't need a new one unless you have already had it out and resurfaced before.
Old Apr 24, 2007 | 04:11 PM
Lubo_25's Avatar
Default Re: fidanza friction disk replaceability and lifespan (FarinaMotorsports)
yea hes right about resurfacing can be done no sweats nothing will happen if .005" is ground off but id resurface it only once if it were me...dont wanna get too close to those c'sink bolts...
Old Apr 24, 2007 | 04:14 PM
sil's Avatar
sil
ahh, so resurface with the friction disk still attached? I thought I'd have to remove it to resurface, don't remember how sunken in those screws were
Old Apr 24, 2007 | 04:44 PM
Lubo_25's Avatar
even when you replace the friction disk you will still have to check the run out of the face and possibly resurface it there even...i dont see one surfacing job doing any harm but only as far until it cleans up(usually around .005" depending on clutch materials) those c'sink bolts should be in a good 1/64th depth...if in doubt always email fidanza on their website! my .02 cents this is just from experience my friend...
Old Apr 24, 2007 | 05:37 PM
sil's Avatar
sil
perfect, thanks for all the responses. The clutch I'm currently using is an exedy stage one and it feels like engagement is starting to go, seems to point to the springs starting to go. The clutch I am thinking to go with now is the exedy OEM or possibly Honda OEM. Thoughts on this setup or the exedy OEM?
Thanks!
cream1316
Jan 4, 2010 06:15 AM
VtecCivic93
Mar 25, 2008 07:36 PM
ek-g6
16
Feb 15, 2008 11:25 PM
bebfsu1
Dec 8, 2005 01:09 PM
civcexcoupeblack
May 9, 2003 01:35 AM
