failed emmision
Old Mar 20, 2005 | 08:51 PM
yeungkaho's Avatar
Default failed emmision
i have a 98 ITR.
modded : 11.5 comp
failed HC. by quite a lot. max allow 86. i got 250
i got new spark plugs. ngk laser double platinum. a new distributor.
i put 94 octane gas in my tank. with some octane booster
car is driven 120 000 km
so quite high mileage.
just put on a high flow cat.
things i am considering . new o2, new spark wires.
on my exhaust, i am getting O2, HC, and CO quite high.,
so i am guessing the mixture is not quite burning, coz of O2
my timing is kinda fucked up too....coz maybe because i raised the comp, and it knocks, so the ecu retards its timing after hard acceleration, but sometimes, it advances to 32 degree....so...i am confused.....any help or suggestions would be great
Old Mar 20, 2005 | 09:42 PM
Lord Helmet's Avatar
Default Re: failed emmision (yeungkaho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeungkaho &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 ITR.
modded : 11.5 comp
my timing is kinda fucked up too....coz maybe because i raised the comp, and it knocks, so the ecu retards its timing after hard acceleration, but sometimes, it advances to 32 degree....so...i am confused.....any help or suggestions would be great</TD></TR></TABLE>
Fix those things first. get the timing back to factory specs. I'd rather have the engine near lean then excessive rich.
Old Mar 21, 2005 | 09:20 PM
yeungkaho's Avatar
thanks.
but any idea in how to fix the timing??
even if i adjust my distributor(jumping the wire also), it still isnt to spec, about a few degree off....
i have power fc, should it change it that way instead??...
or the mechanical way?
SLOWEF1990
10
Oct 13, 2018 02:15 AM
toshko321
Oct 18, 2009 07:15 AM
hip_hop_s0ulchild
May 31, 2007 10:10 AM
SLO Sol
11
Nov 16, 2005 05:51 AM
feelo777
May 14, 2005 08:12 AM
