F23a1 swap
Old Mar 31, 2016 | 05:15 AM
Patrick Kuhn's Avatar
Icon5 F23a1 swap
Okay so I have a 94 civic hatchback recently swapped a f23a1 with a h22 Trans running with a p28 ecu but it wants to bog down on take offs was wondering if anybody had any ideas or if different injectors would solve my problem. Thank you
Old Apr 1, 2016 | 07:13 AM
hondamark35's Avatar
Default Re: F23a1 swap
i don't think the F23 used a resistor box for the injectors like the F22A did. 90% sure. if i'm wrong just add the resistor box. if the motor is all original you shouldn't need to change anything.
some questions on the build and install:
what did you do about the IACV? 3 wire to 2 wire conversion?
which distributor are you using?
are you using the oil pump mounted CYP and CKP sensors?
using a home-built/modified engine harness or a purchased one from Ry-wire or similar?
The P28 is chipped I assume. if so, double check your basemap and find someone near you who can help with a street tune. or go for a dyno tune to get things right. unless you have a mechanical issue or something was wired or connected wrong then you just need to get the ECU to play nice with the new engine.
E-mac
Engine Management and Tuning
Jun 29, 2014 04:54 PM
irishone
Nov 11, 2005 01:36 PM
Boost3d22
Mar 15, 2005 01:59 PM
jadugartir
Feb 23, 2005 03:05 PM
krazeemidget
Nov 11, 2003 10:05 AM
