F22 oil pressure problem
Old Jan 24, 2014 | 11:52 AM
joshledbetter12's Avatar
Default F22 oil pressure problem
My f22a1 has a issue with oil pressure dropping below 10 when it's hot.. Any idea of why? I checked bearings new oil pump balance shaft belt is off new oring for the control jet and new rings. Head was machined and checked. One mechanical Guage and a digital Guage and the factory light comes on. I don't know what I'm missing. Thanks
Old Jan 25, 2014 | 06:13 AM
Default Re: F22 oil pressure problem
Nobody?
Old Jan 27, 2014 | 11:04 AM
Could it be bearings? I didn't use the colored bearings.. Just used king and they were within specs. Do you have to use the colored ones?
Old Jan 29, 2014 | 10:30 AM
I guess this site is dead
Old Jan 29, 2014 | 10:38 AM
1HGEJ2's Avatar
how much psi?
Old Jan 29, 2014 | 05:00 PM
I have about 7 hot idle only after driving on the highway at 70 for 15-20 minutes. It will be about 38 at 3000 rpm and honda specs say 10 idle and 50 at 3000 rpm minimum. Would a oil cooler help there? It only happens when it gets hot if i drive at low rpms for a while the pressure is fine.
Old Jan 29, 2014 | 05:56 PM
F22Master's Avatar
How old is the oil?
Old Jan 29, 2014 | 06:50 PM
Fresh. Changed multiple times and different filters.
Old Jan 29, 2014 | 07:56 PM
I have 2 engines that do the same thing. F22a1 and jdm f22b dohc. New king bearings in both not the colored honda ones tho. And a new pump
Old Jan 30, 2014 | 07:50 AM
F22Master's Avatar
Try going up to the next thicker weight oil
Old Jan 30, 2014 | 09:24 AM
I used 5-30 at first and I put a shim in the relief valve of the oil pump and used 10-30 and a wix filter and no change when hot
Old Jan 30, 2014 | 09:48 AM
Do you think a oil cooler will raise it a bit? Since it only happens when its hot like highway speeds. If you cruise around town slow it's fine??
Old Jan 31, 2014 | 11:22 AM
This site really sucks
Old Jan 31, 2014 | 12:58 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Was just about to give you the answer......
Old Jan 31, 2014 | 01:27 PM
m4xwellmurd3r's Avatar
hot
That isnt going up in oil weight. All you did was change the winter (cold temp) weight.
Go up yo 10w-40 or straight 50 weight
Old Jan 31, 2014 | 04:49 PM
You don't think straight 50 will be too thick? Or hurt anything?
Old Jan 31, 2014 | 04:52 PM
F22Master's Avatar
Try a 15w oil. the oil pressure should increase.
Old Jan 31, 2014 | 11:58 PM
holmesnmanny's Avatar
Are you sure you used the correct oring when you replaced the orifice ? Did you accidentally install it backwards when you retightened it ? I've heard of this happening. Did you apply a tiny amount of oil to help it set correctly ?
Old Feb 1, 2014 | 12:04 AM
1HGEJ2's Avatar
15w ist to much. All vtec engines need 5w40. Full synthetic. Which oil company do u use?
Old Feb 1, 2014 | 03:26 AM
Old Feb 1, 2014 | 04:01 AM
1st, he has a non vtec engine. 2nd, no f or h motor ever had anything but 5w30 or 10w30 recommended for it
Old Feb 1, 2014 | 06:08 AM
Correct non vtec engine. Recommended 5-30 I have installed the oil control jet correctly.... I'm thinking it might be a problem with the bearings.. I done this 2 times 2 engines f22a1 and f22b dohc. Same results. Honda has colored bearings and I didn't realize that and can't figure out how to get the original colors in the right spots and don't want to pay $350 for bearings. I originally used king brand bearings.
Old Feb 1, 2014 | 12:34 PM
Do you think I should try a 50wt oil? I can get 5w50 I believe...
Old Feb 1, 2014 | 06:39 PM
10w40 does the same thing. 7 lbs or less when heated up. Should I try 5w20 maybe? Could the clearance be to tight so I need thin oil?
Old Feb 1, 2014 | 09:36 PM
Anyone?
