F20B: What is the maximum rpm capability?
I have a spare block that would like to built with a h22 head and maybe f23 crank and rods but what I was wonderimg since they don't have oil squiters will that effect them on being able to rev high and what way to go about it if I wished to push the rev limiter a bit up
yes the f20b can rev high, but only if you keep all f20b internals in the block. if you use f23 crank and rods, it will basically just be a full f23 block, which isn't as good at higher rpm.
just so you know, some of the fastest H motor guys are actually destroking the motor to a 2.0L, aka using an f20 crank or similar
Westrock2000
25
Jun 12, 2003 06:00 PM
