Extremely high idle speed
Old Jan 31, 2005 | 09:47 PM
Integer's Avatar
Default Extremely high idle speed
I have a totalled 1994 Integra RS sitting in my garage waiting to have the engine ripped out and put in my Civic. The body is crushed pretty bad but the engine and transmission etc, should be fine. However, when I start the car it idles at about 1000-1500 rpm for a while but after a few minutes it steadily climbs up to......well I had it idling at almost 3000 rpm before I shut it off and nearly cried since this thing used to idle at 1000 even in the cold before it was smashed. I am worried that my precious B18 is messed up and I need it to work by springtime to do the swap. Any tips on how to save it from the junk pile?
Old Feb 1, 2005 | 12:10 AM
Redline130's Avatar
Default Re: Extremely high idle speed (Integer)
Look to see if there are any vacuum lines that could be missing or unattached. Also look for wiring that may not be plugged in.
Old Feb 15, 2005 | 12:24 PM
5litereater's Avatar
Default Re: Extremely high idle speed (Redline130)
i hate to bring this back but was there ever a solution to this problem? im having this exact problems and have all wiring AND vacuum double checked. my tps is good (well it worked fine in my crx) and same goes for the iacv. im stumped and have searched/read every idle topic on this forum.
Old Feb 15, 2005 | 09:10 PM
Integer's Avatar
Default Re: Extremely high idle speed (5litereater)
I will be working on my engine later today, will post any updates if anything actually gets fixed.
Old Feb 16, 2005 | 06:11 AM
mountaindewguy's Avatar
if you can't find whats wrong, call some local mechanics and ask them if you bring the engine in itself, if they can look at it.
don't know where your at but they can do that here
mrx
13
Apr 4, 2009 08:31 AM
IntegraAlteeza
Aug 3, 2005 03:31 AM
Dawsonb17a
Jun 19, 2004 03:44 PM
T-Mo
11
Sep 28, 2003 10:17 AM
tommyd
Apr 29, 2003 11:02 AM
