external oil pumps??
Old Apr 8, 2004 | 05:02 PM
h22 civic's Avatar
Default external oil pumps??
any suggestions?pros cons??priceing?
Old May 2, 2004 | 09:45 PM
bambooluv's Avatar
Default Re: external oil pumps?? (h22 civic)
im in the process of getting a drysump kit put together by peterson, ill talk to mike again and see how much for just the single stage external pump, i think its in the 800-900 range. and well worth it to get rid of the ghetto oil pump gear.....-pdang
Old May 3, 2004 | 07:17 AM
Wes V's Avatar
Default Re: external oil pumps?? (bambooluv)
Maybe I'm missing something, but I don't think there is such a thing as a "single stage" system.
As I understand it, one stage is the pump that evacuates the oil pan and send the oil to the sump. Then another stage is what pulls the oil from the sump and pressurizes the engine.
If I'm wrong, please post something. (I'm not being pissy, I'd really like to know)
Wes
Old May 3, 2004 | 08:03 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: external oil pumps?? (Wes V)
i checked through Peterson's site.
they do offer a single "stage" external oil pump for a "wet" system. essentially replacing your internal oil pump but retaining the oil pan and the filter location
stan
Old May 4, 2004 | 08:04 AM
Wes V's Avatar
Default Re: external oil pumps?? (Stan D)
Stan;
That's interesting.
I don't personally see the advantages being worth going to a single stage system. You would still have to do all the external routing of the oil lines. And as you said, it would still be a "wet" system.
For those that don't know, a "wet" system still uses the oil pan as the oil resevoir. You will get "windage" of the oil and the crankshaft. You also can have the system go dry if the oil moves away from the oil pick-up due to G forces.
On a "dry" system there is a remote resevoir tank. One "stage" pulls all of the oil out of the oil pan and fills the tank. The tank is designed to remove any airation (air bubbles) from the oil and the other "stage" pumps pulls from the bottom of the tank to feed the engine. The tank bottom is much like a funnel shape so it's VERY hard for G forces to push the oil away from there. The remote tank can be as large as you want.
Wes
h22 civic
Jan 16, 2010 05:28 PM
caspers_hatch
Nov 12, 2005 11:37 PM
eag36
Mar 30, 2005 05:40 PM
VolKing
Jul 23, 2004 01:53 PM
