experts only : mind boggler
Old May 10, 2003 | 01:18 PM
  #26
isp built's Avatar
Default Re: experts only : mind boggler (legutki)
i think the map sensor or the ecu is bad try to change out one or the other to see if either or is bad
Old May 11, 2003 | 05:57 PM
  #27
Cory man's Avatar
Default Re: experts only : mind boggler (isp built)
On nonobd cars you dont have to jump anything. Once the CEL comes on the code is stored. Look at the LED on the ecu and you will get the code. On OBD1 and OBD2 cars you have to jumper the harness to get the CEL to blink the code.
Old May 11, 2003 | 09:29 PM
  #28
Snail Tuning's Avatar
Default Re: experts only : mind boggler (Cory man)
so lets get their right u pulled back the carpet and looked at the ecu right? or did u look at the check engine light on the dash and think that that was suposed to flash. also have u reset the ecu? i would recomend doing that before switching your ecus or trying otherthings.
Old May 12, 2003 | 05:36 AM
  #29
HT Chaplain's Avatar
Loved
Default Re: experts only : mind boggler (bmcc72)
i swapped out the ecu with my pm8 ecu from the crx. It ran fine but i got a code 20 and 12. But that my be related to wiring up vtec.
Old May 12, 2003 | 09:49 AM
  #30
LegoZ81's Avatar
I'd say bad ecu or the chip needs to be re-seated DTC 0 (Diagnostic trouble code) is bad ECU. It might be that the new chip has a bad checksum etc.
I'd pull the top cover make sure that the chip is in it's socket and if it is and it is still throwing codes take the ecu back to where you got it and have it looked at.
If you did the chipping make sure all pins of the socket are soldered well.
1993eghatch
Jun 22, 2010 01:54 PM
scoobs001
Engine Management and Tuning
Jun 3, 2010 04:43 PM
Hatch It
Oct 25, 2004 06:15 PM
jsteezy1290
Mar 28, 2004 06:17 PM
garados
Apr 18, 2003 06:34 PM
