exhaust problem
Old Mar 30, 2005 | 05:44 PM
tonezilla's Avatar
Default exhaust problem
is it ok if my exhaust pipe is touching up against that arm ? this is the rear section of the catback where it goes under the arm and to the muffler on a 94 accord lx coupe .
Old Mar 30, 2005 | 05:55 PM
thatbluecrx's Avatar
Default Re: exhaust problem (redxalien)
try bending one of the hangers, it might slightly alter or pull the position of the exhaust off it...
i wouldnt let it rub, its not horrible but not wanted...
Old Mar 30, 2005 | 07:06 PM
tonezilla's Avatar
Default Re: exhaust problem (thatbluecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt let it rub, its not horrible but not wanted...</TD></TR></TABLE>
what would be the worst case scenario if i left it like that ? would anything bad happen ?
Old Mar 30, 2005 | 10:00 PM
Default Re: exhaust problem (LSVTEC_DC2R)
constant rubbing will wear a hole in it eventually... my strut tower bar put a hole in my intake
edit: ooo i know what you should do, pull the exhaust down for a min, take a big hammer and go WACK... clearance in just a few swings...
Old Mar 30, 2005 | 10:05 PM
tonezilla's Avatar
you guys think i can wrap like exhaust/header wrap around it a few times to cushion it between the pipe and the arm ?
Old Mar 30, 2005 | 10:09 PM
i wedged a sponge between a bend in the exhaust and the floor that made a nasty dooof sound when i hit bumps... was only a temporary fix as it fell out after a few weeks, then i fixed it the right way
it might just rub right through the wrap but could work for a while, just fix it, physically..
jdmcivicferio
Aug 19, 2008 09:19 PM
mxjosh17
28
Oct 16, 2007 09:49 AM
m1northreat
Honda S2000
19
Apr 28, 2007 11:31 PM
mrnewguy
Aug 20, 2006 10:43 PM
tonezilla
Apr 2, 2005 01:09 PM
