exhaust problem
is it ok if my exhaust pipe is touching up against that arm ? this is the rear section of the catback where it goes under the arm and to the muffler on a 94 accord lx coupe .
try bending one of the hangers, it might slightly alter or pull the position of the exhaust off it...
i wouldnt let it rub, its not horrible but not wanted...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx »</TD></TR><TR><TD CLASS="quote">i wouldnt let it rub, its not horrible but not wanted...</TD></TR></TABLE>
what would be the worst case scenario if i left it like that ? would anything bad happen ?
constant rubbing will wear a hole in it eventually... my strut tower bar put a hole in my intake
edit: ooo i know what you should do, pull the exhaust down for a min, take a big hammer and go WACK... clearance in just a few swings...
i wedged a sponge between a bend in the exhaust and the floor that made a nasty dooof sound when i hit bumps... was only a temporary fix as it fell out after a few weeks, then i fixed it the right way
it might just rub right through the wrap but could work for a while, just fix it, physically..
mxjosh17
28
Oct 16, 2007 09:49 AM
