Exhaust craziness.
Old Jul 14, 2007 | 08:37 AM
King V's Avatar
Default Exhaust craziness.
Whats the biggest size of pipe i can/should go on my car? I want to put 2 1/2 or 3 inch pipe under her, but would that be too big? I don't want 2 inch, because thats what a cheap muffler shop put on my car. Cut off the factory stuff (which i believ is 2 1/4 inch) about 6 inches from the converter and ran that 2 inch bottleneck crap all the way back, and the car doesn't pull as hard in the higher revs anymore. Do i have to worry about an airflow issue with 3 inch, because in my twisted mind, i think if i ran 3 inch, it would help counteract the bends in the rear portion of the exhaust. InPuTs or constructive criticism would be cool.
Old Jul 14, 2007 | 11:04 AM
hitekper4mance's Avatar
Default Re: Exhaust craziness. (200kCivicSI)
2 1/4 - 2 1/2 is good for NA engines. Dont go any bigger unless you go high HP. Just IMO
Old Jul 16, 2007 | 12:20 AM
bitek's Avatar
don't go higher than 2.5'' if its NA...
torque loss...
Old Jul 16, 2007 | 07:37 AM
Padawan's Avatar
Darth ModerVader
What is your current or planned engine setup?
Old Jul 16, 2007 | 07:45 AM
Dutch_Mofo's Avatar
Default Re: Exhaust craziness. (Padawan)
If you go too big, then exhaust gas velocity will be too low. That means you will lose tq.
Old Jul 16, 2007 | 08:18 AM
King V's Avatar
Hopefully around 2-250 hp eventually. Right now its "160" hp. I was leaning more toward 2 1/2 than 3 inch in reality.
Old Jul 16, 2007 | 08:23 AM
King V's Avatar
Wouldn't a header improve linear flow thru the exhaust versus the stock header style manifold? Like a long tube 4 into 1?
rudebwoy
Oct 27, 2007 05:33 AM
vg7z
Jun 2, 2006 07:01 PM
yellowturbo
Aug 10, 2004 01:12 PM
fOmaNPu
Apr 6, 2003 10:57 AM
sleepy
Sep 5, 2001 06:36 PM
