Erratic Idle **Need Help**
Old Oct 4, 2001 | 08:52 AM
REDBARON's Avatar
Default Erratic Idle **Need Help**
Ok guys here the story: My 88 CRX Si is Idleling funny. This just started last week. After if warms up it starts to iddle erratically. It goes up to about 1500, and then drops to about 800. It keeps doing this, but the car can still run. I have since taken it to the dealership and they dont' know why it's doing this. Someone please help me!
Thanks.
Old Oct 4, 2001 | 09:11 AM
Davep's Avatar
Default Re: ideas
-make sure your coolant system is full
-reset your idle
That's pretty sad that the dealer didn't know how to fix it.
Old Oct 4, 2001 | 09:15 AM
REDBARON's Avatar
Default Re: ideas (Davep)
That's what I'm thinking. They've had the car for a week now, and they still don't know.
Old Oct 4, 2001 | 10:50 AM
SOHCArchangel's Avatar
Default Re: ideas (89-T-Rex)
your fast idle valve is screwed
Old Oct 5, 2001 | 07:42 PM
BreakStuff's Avatar
New User
Default Re: ideas (SOHCkordVTEC)
Common causes of an erratic idle..
1) Coolant Level
2) TW Switch
3) Fast idle control valve
4) Intake air control valve
I would rule out #1 and #2 to the fact it surges when the car is already warmed up and not when its cold.. the mentioned valves can sometime be diagnosed by re-creating the surge and then lightly tapping on the solenoid to see if the problem goes away..
Old Oct 8, 2001 | 04:45 PM
BlingBlingCivic's Avatar
Default Re: ideas (BreakStuff)
my gf's 92 civic had the same problem
it was a gasket that caused it, i wanna say intake but not sure
Old Oct 8, 2001 | 05:17 PM
976's Avatar
976
New User
Default Re: ideas (BlingBlingCivic)
Throwing any MIL codes?
Old Oct 9, 2001 | 07:02 AM
REDBARON's Avatar
Default Re: ideas (B21A)
What's a MIL code???
Old Oct 9, 2001 | 12:10 PM
Ri5e's Avatar
Default Re: Erratic Idle **Need Help** (89-T-Rex)
You may have a vacuum leak somewhere. Check around your intake manifold for air leaks. And check all your vacuum lines for leaks.
self_made
Apr 10, 2021 02:25 AM
xlusiveracer
40
Jan 23, 2017 09:32 PM
redferio
12
Nov 5, 2006 06:00 PM
Eurasia00
Apr 22, 2002 11:37 AM
