engine wont start....could it be timing?
Old Jun 29, 2002 | 04:15 PM
dingusjt's Avatar
Default engine wont start....could it be timing?
i just finished troublshooting all sorts of crap on my d16z6 swap into an 89 lx, i have no ecu trouble codes, no check engine light, its trying to turn over it just wont....also i just put in a new distributor cap and rotor and i AM getting spark!!
someone suggested that my timing could be way off, with my cam and the distributor not in sync, the valves might be open when the distributor is igniting so instead of combusting the fuel in a closed chamber, the fuel is just dumping...can this happen...if so what can i do!!!?
Old Jun 29, 2002 | 06:43 PM
Kamin's Avatar
Default Re: engine wont start....could it be timing? (dingusjt)
then its fuel or timing related.
check the teeth on your camgear and crank pulley.
Old Jun 30, 2002 | 09:35 AM
court's Avatar
25 Year Member
Default Re: engine wont start....could it be timing? (KAMiN)
your spark plug configuration
joeekrub
17
Dec 8, 2022 08:24 PM
dannyk89
Nov 4, 2008 08:16 AM
mpower325
Apr 25, 2007 05:33 PM
thumbtack
Aug 12, 2004 09:11 PM
