engine wont rev over 3k
Old Sep 28, 2003 | 12:39 PM
K20EG's Avatar
Default engine wont rev over 3k
my buddys got a Crx with a B-16 in it recently installed ...harness from dpfi to mpfi was made ...and this is what tis doing
any ideas ...i havent got over to his house to check it out yet...just looking for some insight on it
Old Sep 28, 2003 | 03:41 PM
HatchBox's Avatar
Skoobie no more...
Default Re: engine wont rev over 3k (K20EG)
is it throwing any codes?
Old Sep 28, 2003 | 06:40 PM
Waachback's Avatar
sounds like ignition related.
Old Sep 28, 2003 | 07:03 PM
DexterThEG's Avatar
That's definitely ignition related.. one time when I was playing around with ecu chips, I ended up putting the one it had been running back in and it threw the engine light and wouldn't rev past 4k with no power at all but then it went away
record length run-on
Old Sep 28, 2003 | 07:09 PM
HatchBox's Avatar
Skoobie no more...
Default Re: engine wont rev over 3k (DexterThEG)
K20EG PMed me and he said it was throwing the distributer code...
Old Sep 28, 2003 | 08:24 PM
dvp95's Avatar
Default Re: engine wont rev over 3k (ind3ciso)
May want to check the timing belt. I had this problem on my h22a swap. Redid the timing (especially the balance shafts) and the problem went right away.
Old Sep 28, 2003 | 10:18 PM
K20EG's Avatar
yea imma go check out this POS tommorrow ...then i will go through the steps ...
Old Sep 29, 2003 | 01:32 PM
visi0n's Avatar
your ECU is in limp mode. One of the inputs for the ecu is not reading correctly. Could be ignition timing related.
Old Sep 29, 2003 | 01:54 PM
wickedEFguy's Avatar
Default Re: (visi0n)
does it idle funny at all or is it normal?
Old Sep 29, 2003 | 02:09 PM
HONDADNA's Avatar
recheck the wiring for the map and TP sensor. Also make sure that the vaccuum line for map is hooked correctly. It sounds like the ECU is operatinng Fuel cut mode.
I highly doubt that it is an ignition problem because your not complainning of a misfire, jerking, nor and symtoms that relates to ignition faults. However, it sure does not hurt to check any ways.
Sunrise21Motors
Honda Civic (2006 - 2015)
Nov 2, 2011 09:15 PM
krazy newbie
13
Jan 12, 2010 05:20 PM
UGOT8UP2
23
Feb 18, 2009 07:53 PM
TURBO+GSR+CRX=?
29
Feb 2, 2009 10:18 PM
dropd4door
Apr 5, 2003 03:27 AM
