Engine urethane mounts
Hello guys. help me with some info.
What usual outside diameter of polyurethane engine mount bushings (like Hasport) for street use? So it won't be too stiff for daily use?
thanks!
I'm talking about BARREL O.D. on this pic:
thanks!
One of the biggest problems in most cars is soggy motor mounts. This could be caused by torn or damaged motor mounts or they are just too soft. This can result in a few different problems. In the case of rod shifter manual transmissions, (up to 6g civics and 3g Integras) soggy motor mounts can lead to quite a bit of shifter movement. This problem alone isn't that bad.
Drew Peacock
Dec 3, 2004 03:31 PM
