Engine Rotation Direction Question
Old Apr 27, 2009 | 08:54 AM
bubba_crx's Avatar
Default Engine Rotation Direction Question
I was wondering what direction a b series (specifically a B17) engine rotated. And what direction a 4AG (specifically a 4-AGZE) rotates. Any info would be very helpful.
Old Apr 27, 2009 | 09:13 AM
jdm602's Avatar
Default Re: Engine Rotation Direction Question
ccw on the pulley side.
Old Apr 27, 2009 | 09:42 AM
bubba_crx's Avatar
What about where it goes into the trans... basically I need to know if a b series spins the same way into the trans as a 4ag
Old Apr 27, 2009 | 09:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
No, it does not. Most all engines in cars spin clockwise when viewing the front of the engine (pulley/accessory end), and counter-clockwise when viewing the rear of the engine (transmission end).
Pre-2000 Honda engines are one of the oddballs in the engine world, spinning CCW when looking at the front, CW when looking at the rear. Since 2000, the K-series engine started going into several Honda models, which rotates clockwise like most engines.
So the answer is, B-series engines rotate the opposite direction from 4AG (and all other) Toyota engines and transmissions.
Old Apr 27, 2009 | 01:08 PM
bubba_crx's Avatar
Thanks for the info... so I take it there is no way to make the b series on a yota trans work.. What honda motors spin clockwise?
Old Apr 27, 2009 | 01:28 PM
Transpoquick's Avatar
pretty sure the k series spins cw.
Old May 3, 2013 | 11:18 PM
Dalon honda's Avatar
there is a way and i want to figure it out, it has nothing to do with fuel or the motor just timing and starter/adaptor plate. This is not the first time I have seen a b series spin the other direction usually the only problem is finding a tranny to go backwards
Old May 3, 2013 | 11:20 PM
f20 from the s2000 and the j series and the c series spin clock wise
Old May 5, 2013 | 11:00 PM
Badweather Jim's Avatar
Is there any harm in rotating the crank the wrong direction?
Old May 6, 2013 | 01:30 PM
Community Builder
The crank by itself? Probably not. But if everything is hooked up then you risk problems like timing jumping teeth on the timing belt, and possible piston/valve interference. The T-belt tensioner pulley will not operate properly if the engine is rotated backwards.
Crew Chief
May 2, 2020 03:37 PM
tmurrr56
Mar 18, 2013 04:23 AM
CARMA_626
Nov 7, 2010 07:55 AM
