Engine replacement
Old Aug 22, 2013 | 10:56 PM
Mr. Salon's Avatar
Default Engine replacement
Hi guys I'm new to the site and need so help with my first honda. I have a 2000 cvic ex with a bad motor. The block has a 3 inch hole from a spun rod. I only paid $500 for the car, still worth it cause the body is in great condition. I have gotten hold of a 98 ex for dirt cheap with 71,233 miles on it and want to use the motor for my 2000. My question is can I just pull the motor out of the 98 and just drop it in the 2000 or is there a big difference between the two cars. Both cars are SOHC V-TECH motors.
Old Aug 22, 2013 | 11:01 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Engine replacement
No real difference, swap for swap as long as both are manual/manual or auto/auto. I'd swap the 00 exhaust manifold over as it puts the 02 in the right spot and the design is better than the 98.
Old Aug 22, 2013 | 11:09 PM
Mr. Salon's Avatar
That's the one difference the 98 is a stick and the 2000 is a automatic.
Old Aug 23, 2013 | 04:59 AM
kyden's Avatar
you'll have to swap over the intake manifold. but other than that you'll be fine.
Old Aug 24, 2013 | 09:36 PM
wayneDOHC's Avatar
if your want to put the engine from the 98 into the 00 youll be good if you only plan on using the motor, not the motor and trans. swapping the car from auto to manual is a pretty major project, including running lines for the hydro clutch..
Old Aug 24, 2013 | 10:41 PM
dandim23's Avatar
also the 98 is obd2a and the 2000 is obd2b...not a huge diffrence b/t the two but just figured id let ya kno
Old Aug 25, 2013 | 02:35 AM
Mr. Salon's Avatar
What's the difference?
Old Aug 25, 2013 | 02:37 AM
Mr. Salon's Avatar
Just using the engine and I plan on selling the trani
Old Aug 25, 2013 | 03:30 AM
Technical Hero
Swap the engine and use the intake and exhaust manifolds from the 2000. Use an intake manifold gasket for a 99-00 D16Y8. Everything should be plug and play.
Old Aug 26, 2013 | 01:32 PM
wayneDOHC's Avatar
then should be no problem
Old Sep 8, 2013 | 04:53 AM
Mr. Salon's Avatar
I finally got around to replacing my engine and I took the intake off the 2000 just like suggested. The issue I see now is the port holes look different. Are you sure I don't need to use the head of the 2000 as well?
Old Sep 8, 2013 | 03:15 PM
Technical Hero
Same head just different intake manifold gaskets
Old Sep 8, 2013 | 03:44 PM
nub's Avatar
nub
OP needs to reuse the 99-00 distributor to be able to plug into the stock engine harness.
Old Sep 11, 2013 | 02:18 AM
Mr. Salon's Avatar
Thanks for the advice guys, engine is in without any problems. My next project will be to do some small upgrades but for now I'm just happy the car is running great.
Jordan Bright
Sep 9, 2017 04:55 PM
simers
17
Nov 12, 2015 12:06 PM
denracho
Appearance Build Threads
21
Jan 12, 2010 05:50 AM
ITR1071
Feb 23, 2003 04:13 PM
takamy403
Jun 6, 2002 01:09 PM
