Engine Rebuild parts..
Old Jan 14, 2003 | 12:49 PM
navin's Avatar
Default Engine Rebuild parts..
JW if anyone has the parts for the bearings/seals that you would replace when re-building an engine. Basically I want everything to be fresh, etc.
Also doing pistons/rods, etc. So non of that shtuff.
Old Jan 14, 2003 | 01:21 PM
Spade's Avatar
Default Re: Engine Rebuild parts.. (navin)
Rod bearings, Crank bearings, Cam and Crank seals, and Piston rings.
On the top I would replace the valve seals and have the entire head and block "hot tanked" to clean them.
Old Jan 14, 2003 | 01:33 PM
navin's Avatar
Default Re: Engine Rebuild parts.. (Spade)
suhweet. Thats the info I was looking for, but this thought just popped in my head. Does Honda offer a package deal with seals/bearings for rebuilds or am I gonna have to piece that together myself.
-navin
Old Jan 14, 2003 | 02:00 PM
Spade's Avatar
http://www.hondaautomotiveparts.com your going to have to piece it together on your own
Old Jan 14, 2003 | 02:19 PM
98civicEX's Avatar
what car is this for? i may have the part #'s on hand.
if taking off the head, get the head gasket set, and also get the block gasket set. they'll have pretty much everything you'll need in there. and then get ACL bearings, unless you want to start matching #'s an colors from the crank, and go stock. camp1320.com, earl, and rocket are distributors of the ACL bearings.
[Modified by 98civicEX, 3:22 PM 1/14/2003]
Old Jan 14, 2003 | 03:17 PM
navin's Avatar
Default Re: Engine Rebuild parts.. (98civicEX)
what I have planned for is..
GSR block
ITR head
SI tranny (not that it matters, thought id throw it in there)
dc2_dustin!
Apr 14, 2014 08:46 AM
mcgee*
Jan 6, 2007 08:40 AM
b16 matt
Aug 22, 2005 03:38 PM
KevronsEG
Jan 4, 2003 09:40 AM
paulzy
Jul 16, 2001 08:35 AM
