Engine problems..
Old Oct 31, 2005 | 11:21 AM
djtony5's Avatar
Default Engine problems..
Iight guys, I just check my compression number again today. 200 in cyl 1, 175 on cyl 2, 140 on cyl 3, 200 on cyl 4. Add some oil into 3 and it rises to 175, add oil to number 2 and it rises to 225. I'm scared now that it could be my piston ring, but there are no symtoms or signs that could be my piston ring. The exhaust doesn't blow any smoke at all, during driving or idle. The only problem with the car is blown radiator after radiator, lagging on the motor between 2-3k rpm, cel light on for secondary o2 sensor and misfiring cyl 3. Hardly see any coolant mixing with oil. Maybe it still the blownheadgasket? Or is it definantly the piston rings? Someone please help me out.
Old Oct 31, 2005 | 12:00 PM
sohc steve's Avatar
Default Re: Engine problems.. (djtony5)
how in the hell do you add oil to an individual cylinder?
Old Oct 31, 2005 | 12:48 PM
djtony5's Avatar
Take out the plug spark for that cylinder and add about a teaspoon of oil into it. heh
Old Oct 31, 2005 | 01:03 PM
sohc steve's Avatar
Default Re: (djtony5)
i wasn't calling you stupid, just don't realize why you would do that. It's not gonna do anything but damage. Is the car smoking or what? The bad compression could be because of the valves also. The compression seems somewhat normal for an older motor, your gonna have some difference.
Old Oct 31, 2005 | 01:50 PM
JDMmaster's Avatar
Default Re: (sohc steve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc steve &raquo;</TD></TR><TR><TD CLASS="quote">i wasn't calling you stupid, just don't realize why you would do that. It's not gonna do anything but damage. Is the car smoking or what? The bad compression could be because of the valves also. The compression seems somewhat normal for an older motor, your gonna have some difference.</TD></TR></TABLE>
That is a well known method for determining if bad rings could be causing the lower compression number. Adding oil into the cylinder will help a bad ring seal better under pressure whereas adding oil into a cylinder where the ring is okay will not improve the compression test results much.
Old Oct 31, 2005 | 02:41 PM
djtony5's Avatar
Ty guys, but I'm still wondering if indeed it could be my piston ring. Because the car doesn't blow any white smoke at all and plus the car doesn't burn any oil. But i'm going to take off my head and look at the headgasket and see if it a small leak or something. I'm just afraid that my piston might be the cause of all this, but there is no way knowing, since there are no signs of it.
Old Oct 31, 2005 | 03:03 PM
rainforest's Avatar
sound like you prolly have a little of both.
the easy way to check. (not the most accurate though)
is to start the car with the radiator cap off wait for it to wharm up a little then look for lots of air bubbles coming from the radiator as you rev the engine to around 2000-3000rpms.
that means there is air and combustion gases in the coolent.
the right way to check is a cylinder leak down test. and look for the same thing. as the cylinder is compressed with air.
Old Oct 31, 2005 | 03:36 PM
djtony5's Avatar
Ty for the reply rainforest. A couple of week I did ran the car until it get warm with the radiator cap off. Whenever I rev up the engine, coolant would shoot out. So would it be headgasket or piston ring.
qcpwoner2
May 20, 2017 12:23 PM
FireInTheHead
Nov 4, 2014 04:15 PM
rdssk8rcs1
May 2, 2011 03:08 AM
patrick4588
Dec 21, 2007 03:48 PM
djtony5
Oct 30, 2005 03:35 PM
