Engine Problem EK4 Need Help!!!!
Old Apr 26, 2004 | 12:32 PM
Wuman's Avatar
Default Fuel problems B16 Turbo!!! Need Help!!!
I finished with my Turbo install. I have start my engine tody and the engine makes some clap clap ( sorry for my bad english i am from germany )
And the Air/Fuel Gauge is all all time on green to much fuel. How can i give the engine less fuel?
I have a Vortech FMU and a APEXi Controller
Here are some Pictures of my Setup
Turbo: Turbonetics
Wastegate: Tial - external
Intercooler: Greddy
Blow Off: Tial
Ignition: MSD
Wires: MSD
Management: Vortech FMU
Missing Link with OEM Map Sensor
Boost Controller: Greddy Profec B
Injectors: RC 440's
Cam gears: AEM
Fuel pump: Walbro 255lph
Fuel regulator: AEM regulator
Exhaust: 2.5 in downpipe - 3 inch exhaust 5 Zigen
Thanx
Michael
Modified by Wuman at 1:43 PM 4/26/2004
Modified by Wuman at 12:28 AM 4/27/2004
Old Apr 26, 2004 | 12:58 PM
91DA9's Avatar
Default Re: Engine Problem EK4 Need Help!!!! (Wuman)
Damn that's quite a setup .
What is your fuel pressure set at?
Old Apr 26, 2004 | 01:13 PM
Wuman's Avatar
Default Re: Engine Problem EK4 Need Help!!!! (91DA9)
I dont know how much
Old Apr 26, 2004 | 01:15 PM
vti2's Avatar
it will be stock fuel pressure.
Old Apr 26, 2004 | 09:13 PM
Wuman's Avatar
Default Re: Engine Problem EK4 Need Help!!!! (vti2)
Nobody knows it?
Old Apr 26, 2004 | 09:52 PM
master13g's Avatar
why lessen fuel... add more boost = more power.... he he he
stock fuel psi 35-42
Old Apr 26, 2004 | 11:24 PM
Wuman's Avatar
Default Re: Engine Problem EK4 Need Help!!!! (master13g)
When I start the engine get it already too much fuel and does not run well and smells like fuel. What can i do naow that the engine gets less fuel?
Do it with the Apexi controller?
Old Apr 26, 2004 | 11:35 PM
master13g's Avatar
what you really need is to get your ECU chipped for forced induction. I'm pretty sure you're running the stock ECU so this is probably your biggest problem. Just do some searches on what would be the best ECU for your car and setup. I know there have been many topics with this already. Hope this will help you.
socal_brandon_
May 3, 2004 07:42 PM
Lei Siew Long
Mar 23, 2004 09:22 AM
BSpec24
Jun 10, 2002 07:42 PM
Sh4rky
Feb 21, 2002 09:59 AM
whagkangmakulet
Oct 4, 2001 03:43 PM
