Engine light flicker
Old Feb 11, 2014 | 06:06 PM
KidRuthless's Avatar
Default Engine light flicker
What's up honda tech I've been having this problem the past two months and it happens every other day maybe twice a week. Ill be driving and for a tenth of a second my engine light will light up and shut off. It basically as fast as an eye blink! Any ideas?
1997 civic Dx with stock 1998 gsr b18c1 swap.
Old Feb 11, 2014 | 06:21 PM
preludeNApower's Avatar
Default Re: Engine light flicker
Is it always the same flash?
Is it a flash or a flicker?
If more like a flicker I would think bad cluster/ground/PCM
If a flash, bad PCM
Old Feb 11, 2014 | 06:50 PM
If a flash, bad PCM
Its just a really fast flicker, everything on my cluster is works perfectly fine. So the negative battery cable could cause this issue?
Old Feb 11, 2014 | 07:36 PM
I was referring to something more along the lines of a bad solder joint or one of the dozens of other grounds in the car.
Is the flicker consistent?
Old Feb 11, 2014 | 11:28 PM
I hoping you werent gonna say that lol But nothe flicker will happen periodically it never continues in a short amount of time. Ex. It flicker once then two days later flicker again.
Old Feb 12, 2014 | 04:52 AM
kyden's Avatar
does the car run fine when it does it?
Old Feb 12, 2014 | 05:31 AM
HondaPartsHero's Avatar
Technical Hero
Get a code scanner and see if there are any stored or pending codes
Old Feb 12, 2014 | 03:27 PM
^^^ answer those.
Is this "flicker" the same every time? Same duration and brightness
Old Feb 12, 2014 | 07:55 PM
^^^ answer those.
Same duration and brightness every single time. And How would I pull th code without the engine light actually being on, because I usually jump it with a paper clip then it flashes the code or codes.
Old Feb 12, 2014 | 07:57 PM
Yea I have no problems with the car, I think Im gonna plug up a p72 to see if it picks up any codes, right now i have a chipped p-28.
Old Feb 13, 2014 | 03:18 AM
Technical Hero
Go to autozone or parts store and ask them to scan it, it possibly will have pending codes stored in memory.
Old Feb 13, 2014 | 12:03 PM
Sounds like bad PCM, that is not a normal thing
billybod
Jun 22, 2019 03:07 PM
1clean01
Honda Civic (2001 - 2005)
Jan 18, 2015 04:25 PM
gleake
Jul 23, 2011 08:47 AM
SpoonLx
16
Jul 3, 2005 03:51 PM
