Engine light but throwing no codes.....?
Old Nov 12, 2009 | 10:34 PM
SiTR's Avatar
Default Engine light but throwing no codes.....?
So i took my car out to stretch me legs a little since i had a full bottle and when i went to get on it, it went but after a while threw a check engine light. So after parking it i jump it at the kick pannel to check the codes but it just stays solid as if there is no code. Ive also already tried disconnecting the battery but it sill wont go away. And the car wont let me pass 4k and it feels as if the plugs are fall or some sort of fuel cut. Any ideas......
Old Nov 13, 2009 | 06:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: Engine light but throwing no codes.....?
Sounds like ECU/ECM is in limp mode.
What is the MM&Y of the car? 94
Old Nov 13, 2009 | 07:45 AM
SiTR's Avatar
Yeah im hoping its just the ecu, its a 99 si with an itr swap running on a phearable p28
Old Nov 13, 2009 | 04:27 PM
SiTR's Avatar
anyone.....?
Old Nov 14, 2009 | 07:44 AM
SiTR's Avatar
So last night early morning i had my key turned forward with my motor off when i heard like a whining noise. THe noise is soming from my iac valve behind the tb. So gonna clean it off later adn see what happens....
Old Dec 3, 2009 | 09:38 AM
alltech_hybrid's Avatar
having similiar problem... did you find a solution?
FreddyCarbs
Honda Civic (2001 - 2005)
Jun 4, 2013 06:38 PM
`chrisb
15
Oct 3, 2007 12:15 PM
Jxi8s2k
Jul 15, 2006 05:48 AM
HooberSi
Feb 22, 2006 05:44 PM
Jintegra99
May 14, 2004 07:05 PM
