Engine dies on startup when cold...
Old Nov 21, 2007 | 02:58 PM
Maireeka's Avatar
Default Engine dies on startup when cold...
When i start my car and the engine is cold, it sometimes fails to start. The engine fires, but won't idle. If i crack the gas open, then it will rev to life and run rough for a few seconds. after that it evens out and I can drive it as normal. The car runs beautifully at all other times, screams up to redline, etc.
this happens without regard to outside temperature, it only has to do with my engine temp.
It can happen any time I start the car and the motor is cold.
It happens a little more often after times when I drive the car hard (autox etc)
It happens a little more often when I'm low on gas.
I have a fuel pressure gauge, and from what I can see, my fuel pressure is fine.
I have replaced
plugs (a couple times)
cap
rotor
wires
fuel filter
air filter
valve adjust
fuel system cleaner at the oil change place
the things that seemed to make a diff were the new plugs and the fuel system cleaner, but the only made a minor difference, and it started happening again shortly after.
Any ideas? Only thing I haven't checked is ignition timing, but I don't have a timing light. It's computer controlled anyways, right? What else could it be? I've been fighting this **** since april.
Old Nov 21, 2007 | 09:41 PM
Maireeka's Avatar
Default Re: Engine dies on startup when cold... (Maireeka)
need some fresh ideas on what to do about this please
Old Nov 22, 2007 | 04:29 AM
JimTripp's Avatar
Perhaps something to do with the Idle Air Control? Ill do a little research on this and repost...
Old Nov 22, 2007 | 09:27 AM
db1_jdm's Avatar
Default Re: Engine dies on startup when cold... (JimTripp)
i would completely clean the idle air control valve!
Old Nov 22, 2007 | 11:00 AM
Maireeka's Avatar
Default Re: Engine dies on startup when cold... (db1_jdm)
sorry,, forgot to add it was replaced with a new one. cleaning it did nothing.
i am throwing a cat efficiency code and a emissions leak (i think) code
also some random misfire codes for all 4 cylinders, this happens after i get the startup hiccup.
Old Nov 22, 2007 | 05:06 PM
soulpwr's Avatar
Bad ECT.
Old Nov 23, 2007 | 04:56 PM
Maireeka's Avatar
Default Re: Engine dies on startup when cold... (soulpwr)
wouldn't my temp gauge not work? or wouldnt i throw an ect code?
ect is on the dizzy side of the block right?
Old Nov 24, 2007 | 02:47 PM
JimTripp's Avatar
I have seen older accords with bad ect sensors, the guage still worked. Could be a bad sensor. Pretty sure its the sensor to the left of the exhaust manifold looking under the hood.
Old Nov 24, 2007 | 04:51 PM
Maireeka's Avatar
i'll definitely replace it if it's not too expensive. could be my magic ticket to happy car land
Old Nov 26, 2007 | 04:55 AM
JimTripp's Avatar
well definately post back with the results! im interested now. good luck!
t0mmyt
Jun 6, 2013 10:16 AM
PhilMac23
Honda Civic (2001 - 2005)
Nov 5, 2012 11:30 AM
johnny_bighood
19
Aug 1, 2009 04:21 PM
Shaguar47
Feb 18, 2008 07:25 AM
frontrangefreedom
Mar 16, 2005 07:46 PM
