engine damper
Old Jan 22, 2009 | 08:51 PM
feriotypeR's Avatar
Default engine damper
How do i install the ebay 99 civic sohc engine damper? i tried, couldnt get it
Old Jan 23, 2009 | 12:39 AM
johnlear's Avatar
Banned
Default Re: engine damper
Is this a harmonic crank damper? If so I'd only use a stock Honda item, or an aftermarket item from a very trusted source. If a cheap one fails that may not be a very good thing...
Old Jan 23, 2009 | 08:26 AM
feriotypeR's Avatar
its the torque damper, to stop the movement of the engine
Old Jan 23, 2009 | 01:05 PM
johnlear's Avatar
Banned
Well, you don't specifically detail what problem you are having doing this, so it's hard to offer advice. To limit engine movement I would think that harder engine mounts (particularly the rear mount and the bushes on the front brace) would be more effective than some form of damper...
Old Jan 25, 2009 | 02:15 PM
feriotypeR's Avatar
well i already have the damper, i just need some1 to tell me how to install it. its the cheap torque damper from ebay
Old Jan 25, 2009 | 03:08 PM
cockerkid008's Avatar
look at pictures of how other people mounted theirs
Old Jan 25, 2009 | 05:32 PM
Dann6968's Avatar
Orient it front to rear (as opposed to side to side). Find somewhere you can bolt both sides to, and voila.
See if you can solve this on your own. It always feels good when you do that and it works.
RICO_
Honda Civic (2006 - 2015)
58
May 29, 2009 11:51 AM
futomame
Honda S2000
Oct 13, 2006 02:25 PM
hondaapi
Apr 11, 2006 09:56 AM
yellowturbo
Sep 8, 2005 04:10 AM
AgentJam
Aug 7, 2004 07:55 PM
