Engine cutting out...
Old Jan 9, 2003 | 05:36 PM
sherman's Avatar
Default Engine cutting out...
I swapped a 99 Ex motor into my 92 vx hatch. Now when the car is cold and in closed look it acts like there is a vaccume leak and it reevs itself from 1500 to about 2000. I cleaned out the IACV and it still does it. I checked codes and it said IACV and the heated O2 sensor are not functioning right. Now i know that the o2 sensor will not work since it is a 5 wire. Does anyone know what i can do about puting a 4 wire in? The plug for a 4 wire is different than a 5 wire, right? Could the falty o2 sensor be causing this? Thanks for all of the help.
Old Jan 9, 2003 | 07:08 PM
Turbo Powa's Avatar
Default Re: Engine cutting out... (sherman)
yes get the correct o2 sensor
Old Jan 9, 2003 | 08:54 PM
sherman's Avatar
Default Re: Engine cutting out... (Panda EK)
I know i need to get this but how am i supposed to hook it up??
Also after the car is warmed up at 1500 rpms it will bounce to 1600 rpms or so relatively quickly. I unhooked the TPS and it goes away but then the engine will not rev higher than 2000 rpm.
Also i do not have the IAT sensor hooked up. Is it vital for it to be kooked up?
Thanks, the help is greatly appreciated.
Old Jan 10, 2003 | 10:40 AM
Turbo Powa's Avatar
What do you mean how do you hook it up? It should be plug and play if its the correct o2 sensor. Why is your car idle at 1500? Do you know how to adjust your idle? Unhook the TPS and adjust the TPS screw.... i cant remember exaclty how to do it because I got my radio stolen today... got to much **** on my head.... if I remember, i'll let you know..
Old Jan 10, 2003 | 08:08 PM
sherman's Avatar
Well i dont think that you understand what im saying. Is there anyone else that can help me out.
BLJ-93eg
Apr 27, 2007 02:03 PM
1.8
Mar 29, 2006 10:30 PM
boredracer408
Dec 3, 2005 03:06 AM
chad
Aug 25, 2004 01:58 PM
