engaging clutch doesnt move the car..
Old Feb 16, 2005 | 09:12 AM
thatbluecrx's Avatar
Default engaging clutch doesnt move the car..
quick lil question, yes i know how to drive extremely well...
if i hold my clutch at the engagement point my motor bogs pretty hard and littlerly i gotta take like 5-10 seconds for the car to 'walk off the clutch' .. it just has no "ummphhh", almost making u want to burn it a lil, again im not stupid somethings not right with the car lol... my idle is about 700 is it too low? is my clutch goin? whats up with that?
edit: b16 crx with y1 cable if this means anything
Modified by thatbluecrx at 10:36 AM 2/16/2005
Old Feb 16, 2005 | 03:36 PM
evil civic's Avatar
Default Re: engaging clutch doesnt move the car.. (thatbluecrx)
700 is a good idle...sounds like your clutch is gone if it just doesnt have any grad to it...
Old Feb 16, 2005 | 03:59 PM
Slow ass EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil civic &raquo;</TD></TR><TR><TD CLASS="quote">700 is a good idle...sounds like your clutch is gone if it just doesnt have any grad to it...</TD></TR></TABLE>
Old Feb 17, 2005 | 05:56 AM
JimBlake's Avatar
Default Re: engaging clutch doesnt move the car.. (evil civic)
If the clutch were slipping the engine would rev when you try to engage the clutch. You say it 'bogs pretty hard' but what exactly does that mean?
Old Feb 17, 2005 | 07:36 AM
Default Re: engaging clutch doesnt move the car.. (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If the clutch were slipping the engine would rev when you try to engage the clutch. You say it 'bogs pretty hard' but what exactly does that mean?
Yes I dont think its slippin JUST YET...
by bog i mean the obvious when engaging the clutch at a stop the motor goes to stall...
but holding the engagment point the motors at like 200rpms and it just cant kick itself off the clutch"...
its hard to explain and im trying to not make myself look like retard explaining hahaha
still stock clutch bought the motor with 40xxx, currently has 70+
Old Feb 17, 2005 | 07:38 AM
snatch's Avatar
So you're saying it bogs when you reach the engagment point, and then continues to bog even after you've let the clutch out all the way??
Old Feb 17, 2005 | 07:40 AM
Default Re: engaging clutch doesnt move the car.. (******)
no no im saying that the "bog" is just the normal coming of the clutch about to stall the car...
the problem is, it WONT come off the clutch unless i give gas, no matter what, or how long i hold the engagement point...
Old Feb 17, 2005 | 07:49 AM
JimBlake's Avatar
When it bogs, try disengaging the clutch rather than hold the engagement point. Does it still remain somehow, partly engaged?
Has your clutch suddenly become much more 'grabby'? So it won't slip to prevent stalling the engine??
Old Feb 17, 2005 | 07:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Has your clutch suddenly become much more 'grabby'? So it won't slip to prevent stalling the engine??
ooooo that one MIGHT be a symptom...
if i said it felt SLIGHTLY "chattery on a downshift" would that mean its 'grabby'??..
Modified by thatbluecrx at 9:13 AM 2/17/2005
Old Feb 17, 2005 | 09:19 AM
JimBlake's Avatar
I'm sorta thinking about a damaged clutch disk; maybe stuff is coming off the disk so it's kinda harder to control the engagement.
The only time I've ever had anything like this was a broken spring in the hub. Mine just locked up solid & wouldn't do anything. Pretty much like a broken clutch cable. But I guess sometimes you can just get smaller-scale damage??
zach1288
16
May 9, 2007 05:57 AM
ic89
Oct 16, 2006 05:22 PM
faSHOwidIT
Jan 5, 2005 08:53 AM
DANgerous
Apr 4, 2004 01:37 PM
rody084
Mar 23, 2004 06:00 AM
