Emanage & FMU?
Old Sep 17, 2004 | 08:24 AM
Hyaboosta's Avatar
Default Emanage & FMU?
I have a 2002 civic and I am almost done piecing together my custom turbo. I have a returnless fuel system so for the fuel set up I went with RSX-S Injectors(330cc) MSD Inline fuel pump, aeromotive Digital FMU and VAFC. But what I was told is that the vafc would be manipulating my map, so when I use it to lean out the fuel it will throw off my timing because it would still be on a fuel map for N/A.
IM switching out the VAFC for an Emanage but by using the emanage to tune the fuel,injectors and ignition directly will the FMU be doing anything or just be useless,Maybe like an overpriced FPR?
Old Sep 17, 2004 | 10:40 AM
turboteg2nv's Avatar
Default Re: Emanage & FMU? (Hyaboosta)
Nope, the FMU will be useless if you get E-manage.
Old Sep 19, 2004 | 06:25 AM
Hyaboosta's Avatar
Default Re: Emanage & FMU? (turboteg2nv)
would I be able to tune the fmu for a rough fuel tune and use the emange for fine tunning? or would it make no difference?
Old Sep 20, 2004 | 10:44 AM
No, you need to do research on how stuff works. An FMU is not adjustable, it will raise fuel psi a certain rate for every pound of boost it sees.
Old Sep 20, 2004 | 03:04 PM
Hyaboosta's Avatar
No sir. You need to do some research. I have an aeromotive digital fmu. It is adjustable. http://www.behrents.com/Mercha...=PROD
KseriesSLUG
Feb 28, 2005 10:52 AM
Hyaboosta
Sep 21, 2004 10:06 AM
si_blues
Aug 2, 2004 06:35 PM
TurbothisLS
Sep 22, 2002 07:22 AM
tararan
Mar 14, 2002 12:49 PM
