Electronic Issues
Old Apr 17, 2011 | 05:29 PM
Slacker93eg's Avatar
10 Year Member
Default Electronic Issues
Previous owner of my new EG was a hack. I have wires everywhere, connectors unplugged etc. I'm assuming most go for the AC that was removed in the engine bay. Anyway, on to why I came here.
Problem: When I hit the brakes, my headlights and everything dim real low. Now I first thought maybe the battery, but it is a newer battery he claims. I'm going to test that tomorrow to see what it's putting out.
Could it be the alternator isn't recharging fast enough? Is there a larger amp alternator or anything like that, that can be put in it's place?
Old Apr 18, 2011 | 07:00 AM
frankenghia's Avatar
Default Re: Electronic Issues
It sounds like something is grounding out when the brakes are applied.
Old Apr 18, 2011 | 07:14 AM
kyden's Avatar
i doubt a larger amp alternator is gonna fix your problem. check your grounds first?
Old Apr 19, 2011 | 05:20 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ start by checking/redoing the main grounds and main powers...
Both batt. posts and clamps, the batt. to chassis ground, the chassis to engine ground, the batt. to engine bay fuse box, batt. to starter, alt. to engine bay fuse box, [both ends] and the main fuses, all these connections should be undone, both contact surfaces cleaned and then connection reconnected making sure they are tight.
If the above does not solve your problem, have a proper load test done on the charging system, it will tell you the condition of the alt. and it's output, the condition of the batt.
Most batt./alt. shops will do this for free, it only takes a few min., nothing has to be removed from the car. 94
Cubafrmdanycs
Jun 26, 2016 10:28 AM
ekHatChAddIcT
15
Mar 16, 2011 06:58 PM
deauboy
Oct 14, 2010 05:36 PM
flatblack-h22
Apr 3, 2006 08:30 AM
