ek wont start pleaseeee help pleasee
Old Aug 23, 2011 | 10:24 AM
jkurver's Avatar
Default ek wont start pleaseeee help pleasee
hello am new to this site ive always guide my self tru here but never acually registered. anyways i have a anightmare 97 ek. car has a minime swap d15b7block/and 93 vetc head. setup is 93 obd1 dizzy spliced to my factory obd2a engine harness. car turns over sparks there fuel and it wont start. timings on point dizzy rotor faces number 1 am using a P2P ECU AND ALSO HAVE TRYED MY PO6 ecu chipped and nothing. again fuel pump primes theres spark strong spark fireing orders right compression is on point fuses are good please helppp!!!!
Old Aug 24, 2011 | 09:34 AM
jkurver's Avatar
Default Re: ek wont start pleaseeee help pleasee
bump please need help with this car dont want to lose my job?
Old Aug 24, 2011 | 09:57 AM
civickiller's Avatar
no semi combusting?
Old Aug 24, 2011 | 12:43 PM
jkurver's Avatar
dont really know what u mean by that
Old Aug 24, 2011 | 12:59 PM
grumblemarc's Avatar
The Grumpiest
CEL?
Old Aug 24, 2011 | 01:02 PM
The Grumpiest
Injectors spraying? What color is the spark? Why are you not using a P28?
Old Aug 24, 2011 | 01:34 PM
jkurver's Avatar
cluster stop working so i cant pull cels, spark is sometime stong and sometimes week injector pulses i have the stock p2p which started the car ones and never started after it the coil when out.i replaced dizzy, i tryed useing a chiped p06 i have and also nothing. i spliced the obd1 dizzy onto my obd2a harness according to diagrams showed on other treads
Old Aug 24, 2011 | 01:37 PM
jkurver's Avatar
i dont have anyother idea till why the car dosent start? am also using an auto engine harness pluged what i can also plug the ivac nothing , i checked fuses everything
Old Aug 24, 2011 | 03:47 PM
The Grumpiest
Sounds like a hack job, no offense. Most swaps don't run due to faulty wiring jobs and/or timing issues. Take it to a mechanic.
Old Aug 25, 2011 | 12:51 PM
maybe you mixed up map and tps?
ColbyCD5
Apr 3, 2012 04:16 PM
tigmandick
19
May 21, 2010 10:13 PM
JDMcivicSiEG6
10
Oct 20, 2008 07:25 PM
