EK not starting
Old Aug 18, 2004 | 08:21 AM
b00$tedEK's Avatar
Default EK not starting
I recently bought my car from an auction, its decent enough. im trying to find the problem with my car.
Here are things that happend when i started the car:
i turn on the engine, the starter clicks, and then engine turns over, but theres no power. then i stoped trying, a few days later i came back to it, and i tried it, it stops turning over and i turn the key again theres no sound, then all i can her is the motor click a lot.
anyone know the problems or anything? there are some relays missing in the fuze box which i will replace, but i dont think thats the real problem. Toss me some advice and thanks for your time.
Old Aug 18, 2004 | 04:33 PM
doublejz's Avatar
Default Re: EK not starting (D16zc Turbo)
dead battery
Old Aug 22, 2004 | 03:43 PM
b00$tedEK's Avatar
Default Re: EK not starting (doublejz)
The batter still works good, cuz i turn on the lights and they still shine bright.
Old Aug 23, 2004 | 11:55 AM
doublejz's Avatar
maybe a bad starter?
Old Aug 23, 2004 | 08:55 PM
b00$tedEK's Avatar
Well, i tried a different battery, and now it turns over, but im not gettng any ignition still, maybe spark plug number 1? im gunna go check it in a few mins and i was wondering if there are any other possibiltys why my engine turns over but no spark, and i checked my distruber cap, its fine, but should i sand down the lil metal peice?
Old Aug 24, 2004 | 11:27 AM
doublejz's Avatar
can you hear the fuel pump priming? maybe main relay
If you don't have any spark replace; rotor, cap, plugs and wire. Who knows when the last time they were changed.
Old Aug 25, 2004 | 10:19 PM
b00$tedEK's Avatar
Well the spark plugs work, and then i havent checked my fuel injectors yet, but i do know that it primers even tho i havent checked because when i was doing the spark plug, there was a puff of gas, so maybe i need to check that
im also about to go do a compression check to see wassap because right now i think that might be the problem
Old Aug 29, 2004 | 08:04 AM
b00$tedEK's Avatar
IT STARTS!!! i had to put more gas and change the injectors. but then now it wont stay on, haha as i start the car with my foot on the gas, as i let it go, it dies, so just idle and tuning left!!!
Honda13
May 13, 2009 08:36 AM
Fook_me_honda
Apr 26, 2009 09:38 PM
krnfly2damoon
Sep 5, 2005 08:49 AM
stickshift
Jul 17, 2003 06:57 PM
ramdog
Nov 13, 2002 05:17 PM
