EGT & Wideband AFR question
Old Mar 18, 2013 | 03:43 PM
Ribs93's Avatar
Default EGT & Wideband AFR question
Im beginning my first turbo build, and today I decided to dig a bit into what gauges ill be using. I want the interior to be clean and simple, im not interested in having a ton of gauges - im going to have a Sard Stack cluster displaying oil T, oil P, water T, and of course speed and RPM's, also a custom dashboard with three gauge ports where the vents are located on the OEM panel, ill have a Turbosmart eboost2 in one, and the other two are undecided. What I want to know is if I use a wideband AFR, is an EGT gauge necessary? If not, ive been reading a bit of the pro's and con's, what do you guys personally prefer to use over the other?
Ribs93
Mar 18, 2013 08:20 PM
Charlie Moua
Sep 29, 2010 07:16 AM
Almost Boosted
Jun 3, 2006 04:18 AM
YellowR2000
Jun 9, 2002 06:10 PM
IntegraR0064
Jul 2, 2001 09:08 PM
