Effects of low gear oil
Old Aug 25, 2004 | 11:55 AM
DC2_TEG's Avatar
Default Effects of low gear oil
What are the effects when you have real low gear oil for a m/t?
I noticed under my car on the tranny, something seems to be leaking. Its definatly not engine oil, and is more like a clear, odorless fluid. Gear oil does have a odor to it correct?
Old Aug 25, 2004 | 12:20 PM
im_poor's Avatar
Default Re: Effects of low gear oil (DC2_TEG)
you shouldn't be using gear oil in a honda trans.
Old Aug 25, 2004 | 12:24 PM
DC2_TEG's Avatar
Default Re: Effects of low gear oil (im_poor)
I use brake fluid to fill the clutch resevoir, but someone told me that you put gear oil in the actual tranny. I havnt put any gear oil in yet, and thanks for letting me know. Then it would probably be brake fluid leaking? I refill my clutch resevior every so often.
Old Aug 25, 2004 | 12:47 PM
acy76's Avatar
Sounds like fluid from the slave cylinder. Brake fluid does have a distinct (di-stinkt??) smell, and it has an almost sticky feel if you rub it between your fingertips.
shawnlee250
Honda Civic (2001 - 2005)
14
Sep 7, 2011 01:12 PM
07galaxygrey4dr
Honda Civic (2006 - 2015)
21
Jul 27, 2007 10:12 AM
MtnCRX
26
May 24, 2005 05:53 AM
MtnCRX
Apr 24, 2005 06:36 PM
WS6Dreams
Nov 26, 2002 07:36 PM
