edelbrock tb tps wiring?
I have a dalebrock 75mm throttle body and I'm having issues making sure I correctly connected the wires seeing as now I'm getting a tps code. I need someone who has done this installation and knows exactly for sure(not I think this is how it goes)what wire connects to what. I've seen a lot of searches for this but not one has a definitive answer, just guesses. I believe I have wired it correctly and may a faulty tps. PLEASE HELP.
Scored a factory mustang tps and problem solved. The tps that came with the dalebrock was defective. I had purchased the unit brand new.
I've got one too and had the same damn problem. You should get a plug off of an early 90s model Ford V8 truck and solder it into the Honda wires. That way you can easily disconnect it if need be!
