ECU serial #, what type of ECU is this?
Old Dec 30, 2003 | 08:42 AM
Renegade's Avatar
Default ECU serial #, what type of ECU is this?
Besides it being a P28, is it auto or manual and what model car?
37820-P28-A01
Thanks
Old Dec 30, 2003 | 12:25 PM
Katman's Avatar
Default Re: ECU serial #, what type of ECU is this? (Renegade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">Besides it being a P28, is it auto or manual and what model car?
37820-P28-A01
Thanks</TD></TR></TABLE>
its a 5speed P28 ecu.
The "A01" is the dead giveaway.
what model is it from? well its either from an 92-95 EX coupe or Si hatchback. EX/Si's all use a P28 ecu since P28's are the designated ecu to operate the D16Z6 engine.
Old Dec 30, 2003 | 12:38 PM
Renegade's Avatar
Default Re: ECU serial #, what type of ECU is this? (Katman)
ok, then what is an A52?
I have a Mini convesion on my CRX, but this A01 ECU will not start the car, where the A52 that I use on the integra will. Does that mean the ECU is BAD, can it be repaired?
thanks
Old Dec 30, 2003 | 02:47 PM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
what model is it from? well its either from an 92-95 EX coupe or Si hatchback. </TD></TR></TABLE>
Don't leave out the del sol's.... the si's had d16's and p-28's too!
Old Dec 30, 2003 | 04:02 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">ok, then what is an A52?
thanks</TD></TR></TABLE>
The A52 is an automatic ECU, and unless it has been converted to manual, you should be getting a CEL. There is no reason why the A52 would allow the car to start where the A01 won't, unless the A01 is defective. It sounds like the transistor that drives the ignitor has gone bad. Check to see if you have spark. I myself, or one of the other members here who deal with ECUs should be able to repair it.
Old Dec 31, 2003 | 01:41 AM
Katman's Avatar
Default Re: ECU serial #, what type of ECU is this? (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">
Don't leave out the del sol's.... the si's had d16's and p-28's too! </TD></TR></TABLE>
doh! thats right...forgot about that *** mobile...
Old Dec 31, 2003 | 01:54 AM
DC2_9's Avatar
i bought a p72 ecu not that long ago, it has a barcode. supposedly the barcode is like a serial number. where can you go to check to see if the ecu is legit? or that is not a problem.
Old Dec 31, 2003 | 01:59 AM
Katman's Avatar
Default Re: ECU serial #, what type of ECU is this? (DC2_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_9 &raquo;</TD></TR><TR><TD CLASS="quote">i bought a p72 ecu not that long ago, it has a barcode. supposedly the barcode is like a serial number. where can you go to check to see if the ecu is legit? or that is not a problem.</TD></TR></TABLE>
I've never tried to see if an ecu is 'legit' personally.
You might wanna try the Acura dealership for starters.
Old Dec 31, 2003 | 03:05 AM
DC2_9's Avatar
maybe im wrong but i've heard that a lot like most items on the car, they can be traced, well not if the serial number is taken off. the ecu is a pretty high price item, at the dealer that is.
Old Dec 31, 2003 | 07:15 AM
Renegade's Avatar
well the A52 must have been converted, cause that is the one I use on the integra.
Can the A01 be repaired if it is bad or it is pretty much dead?
Old Dec 31, 2003 | 10:02 AM
91EFate's Avatar
i have a question, i have a dohc zc and im using a 89 teg ecu (37820-pg7-6640) but now mycar won't start. i was thinking that maybe it was because i switched to using a 92-95 civic alternator. could that be it?
Old Dec 31, 2003 | 10:12 AM
Kendall's Avatar
Default Re: (avirex_man_2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avirex_man_2000 &raquo;</TD></TR><TR><TD CLASS="quote">i have a question, i have a dohc zc and im using a 89 teg ecu (37820-pg7-6640) but now mycar won't start. i was thinking that maybe it was because i switched to using a 92-95 civic alternator. could that be it?</TD></TR></TABLE>
The alternator only charges the battery, if it won't start with a fresh battery, then the problem is not the alternator.
NstyGrnHatch
Dec 28, 2004 03:58 PM
dirty-t
15
Sep 10, 2003 04:59 PM
TodaTeg
May 20, 2003 02:49 AM
Inaniac
Jun 19, 2002 01:07 PM
Nebula
May 31, 2002 12:13 PM
