Ecu question???????
Old Dec 5, 2003 | 05:08 PM
1BadDC2's Avatar
Default Ecu question???????
i have a b18b ls ecu obd2 and i am buying the obd2 to obd1 conversion harness and i also have everything i need to chip but what ecu should i go with? thanks- will
Old Dec 5, 2003 | 06:20 PM
XSSIVE's Avatar
Default Re: Ecu question??????? (1BadDC2)
i don't know what setup you have in your car, motor etc...so, if you have a gsr manifod in the car with secondaries you need a p72 to control them, if not, a p28 is fine and is what most use.
-Mike
Old Dec 6, 2003 | 12:16 PM
stockLS's Avatar
Default Re: Ecu question??????? (XSSIVE)
hey man do you need an obd1 ecu??? for an ls? i need an obd2 ecu for my ls i am willing to trade if you need one pm me and we can work out a deal mine for yours with a little money or something!
Old Dec 6, 2003 | 06:53 PM
TRuST's Avatar
You can use a OBDI PR4 or OBDI P75 ECU.
Old Dec 6, 2003 | 11:04 PM
dohcnotec's Avatar
Default Re: Ecu question??????? (TRuST)
PR4 won't give same performance on a B18b (it's made for a B18a). Get an obd1 ecu cus u probably won't find too many people in the states that can chip an obd2 ecu, and on top of that, you probably don't need it chipped since your asking this question.
Old Dec 8, 2003 | 05:18 AM
TRuST's Avatar
Default Re: Ecu question??????? (dohcnotec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcnotec &raquo;</TD></TR><TR><TD CLASS="quote">PR4 won't give same performance on a B18b (it's made for a B18a). Get an obd1 ecu cus u probably won't find too many people in the states that can chip an obd2 ecu, and on top of that, you probably don't need it chipped since your asking this question.</TD></TR></TABLE>
In stock form, the P75 will probably perform better than the PR4 on a B18B but once chipped they will performance extactly the same. Since, both the OBDI PR4(92-93) and OBDI (94-95) have extactly the same circuitry but have different programs.
Old Dec 8, 2003 | 08:34 AM
pills_PMD's Avatar
you dont' need a p72 to run IAB's on a gsr manifold.. a p28 can be modified to do so... but he has an LS anyways it appears
Old Dec 8, 2003 | 10:04 AM
TRuST's Avatar
Default Re: Ecu question??????? (pills_PMD)
What modification do you need to do to the P28 to control the IABs ?
heeltoehonda
Mar 14, 2010 06:42 PM
slo_ej8
Apr 8, 2008 04:34 AM
tranceologist
Aug 28, 2005 05:05 PM
AG3_Teg
Mar 29, 2005 07:18 PM
ShowtimesDC2
Sep 14, 2003 09:14 PM
