ecu question
Old Oct 9, 2005 | 06:21 AM
planetstereo's Avatar
Default ecu question
can high revving cause an ecu to malfunction sometimes and not others?
or possibly can that do a distributer sometimes and not others?
i ask because im still getting an eratic idle.can a bad ecu cause this??????????
Old Oct 9, 2005 | 10:00 AM
doublejz's Avatar
Default Re: ecu question (planetstereo)
ecu, distrib, iacv, vaccum leaks.....
what do you mean by eratic idle?
Old Oct 10, 2005 | 05:15 AM
Default Re: ecu question (doublejz)
IT REVS UP TO 1200 THEN DROPS TO 300-400 AND ALMOST CUTS OFF. BUT ONLY AT STOPLIGHT.WHATS THE WAY TO CHECK VACUUM LEAKS OTHER THAN SPRAYING CARB CLEANER OR STARTING FLUID
Got..BOOST??
Dec 5, 2011 01:54 PM
96CIVICEX
May 26, 2009 07:45 AM
§95HATCH§
May 16, 2009 07:19 PM
Adam.C
Mar 29, 2004 02:22 PM
