ecu pinout question
Old Nov 14, 2008 | 07:04 AM
JBLAZE622's Avatar
Default ecu pinout question
i was wondering if anyone knows wich pin is for the distributor tach signal for an OBD1 ECU
Old Nov 14, 2008 | 07:11 AM
GhostAccord's Avatar
Default Re: ecu pinout question (JBLAZE622)
The tach signal does not go to any pin on the ECU. It goes directly from the ICM, in the dizzy, to the tach/instrument cluster. The Vehicle Speed Sensor (VSS) is B10
Old Nov 14, 2008 | 07:50 AM
Relic1's Avatar
Default FV-QR
A21 & A22 are the ignition signal, but it's different than the actual tach signal.
Blue wire on the back of the cluster, driver's shock tower, or at the distributor.
RichardLSX
31
Jun 5, 2011 06:23 PM
em1si
May 9, 2007 02:58 PM
Chase
33
Sep 29, 2005 07:53 PM
Petah
Jun 1, 2004 11:24 AM
b20guy
Apr 11, 2003 05:12 PM
